第3頁,共20頁 第一第一 1234513 ... 最後最後
顯示結果從 21 到 30 共計 194 條
    我想买一份呀。。。我在上海能买吗????
  2. The Following User Says Thank You to sonyfun For This Useful Post:
  3. #22
  4. #23
    我想組一台專為音樂的電腦耶預算大概要多少壓~~~~
    現在用的想~~專玩遊戲就好
    看了P大大的~~一堆心得但是還不是到要怎樣下手~~
    有人大大要幫我組嗎><~~
    真誠
  5. #24
    JPLAY v4.3 with DSD and ASIO support
    JPLAY v4.3 introduces DSD over PCM (DoP) and support for ASIO interfaces as well as many improvements. Download now!
    Changelog:
      • support for FullScale Hibernate under Windows 8
      • support for ASIO (applicable only to DACs that have an ASIO driver): In theory, ASIO is most-direct software interface to DAC: But does it sound better than Kernel Streaming? Share your experiences at jplay.eu/forum/jplay/asio!
      • support for DSD over PCM (DoP) standard for DACs that support it (DFF & DSF file types)
      • support for 32bit float WAV files – will be converted to 32 or 24 integer depending on driver
      • Support for Hibernate playlists for iPad’s JRemote
      • It is now also possible to start JRiver in MediaServer mode i.e. without GUI and control playback via JRemote on headless systems for best user experience and sq! (to activate, open ‘jplay_for_jriver.settings’ file after first startup and follow instructions)
      • JRiver will now be started automatically by plugin if it is not running
      • In some cases plugins could ‘freeze’ requiring restart – fixed
      • Simply sounds better – upgrade now!!!
    Detailed instructions (with pictures) on how to setup JPLAY are available here. Please read them before contacting us. Thank you.
    Enjoy and post your impressions on our forum
    If you have NOT received your personal jplay copy, please check your spam folder prior to contacting us at
    [email protected]
    之前有買過,如果沒有收到新版的網友~請將您的註冊資訊回信給 [email protected]
    還沒有購買的歡迎找我優惠代購^^
  6. The Following User Says Thank You to 小余 For This Useful Post:
  7. #25
    原廠表示已經寄送新版軟體給大家囉~~沒收到的請檢查一下垃圾信件~
    真的沒收到請將您的註冊資訊mail到 [email protected] 唷!
    We sent mails to everybody yesterday evening - If somebody did not get it then our mail ended up in spam folder or was simply rejected by mail server (we got couple notifications of 'invalid' emails).
    Best thing is to send mail to [email protected] so we can respond to correct e-mail!
  8. The Following User Says Thank You to 小余 For This Useful Post:
  9. #26
    小余,我要幫電腦白痴 rendzaw 代買一份 32/64皆要的 jplay!
    引用 作者: 小余 查看文章
    1. 回覆在此跟小余確認要代買幾份以及版本
    2. 悄悄話給小余,內容請包含你要註冊的英文名E-mail信箱,並告知要32Bit64Bit還是兩者都要的JPLAY版本 (注意XP無法使用)
    3. 等待小余悄悄話回覆您匯款帳號,請轉帳付款 3,500/份 到小余的帳號,並告知轉出帳戶末五碼
    3. 確認收到款項後,小余會通知原廠寄發JPLAY到你的信箱
    4. 日後有升級原廠也會直接寄到你的信箱 (免費)
  11. #27
    ok
    自己人我會算貴一點的
  12. #28
    引用 作者: 小余 查看文章
    ok
    自己人我會算貴一點的
    好的,我會跟 rendzaw 報帳說你賣我一萬元,多的錢我污了,臭名你擔!.......
  13. #29
    詐騙老溼....
    哈哈
    再麻煩您了~已經悄悄話給您了
  14. The Following User Says Thank You to 小余 For This Useful Post:
  15. #30
    噢....................我看到了...嘿嘿嘿...
  16. The Following User Says Thank You to rendzaw For This Useful Post:
