顯示結果從 1 到 1 共計 1 條
主題: TIDAL Agoria
    預設 TIDAL Agoria
    第一對使用最新研發的箱體材料:TIRALITTM,也是第一對使用獨家Sunray-CIC技術設計兩顆11吋低音與三顆超低音散熱器。全被動式低音-EQ-Variotermianl、多重高音曲線調整以及超彈性低音散熱調節系統,適合大、中、小的房間。當然也可使永TIDAL LPX技術主動式驅動....
    The TIDAL Agoria It is the first speaker with our all new developed cabinet material:TIRALIT ™. The first one with our exclusive Sunray-CIC technology designed with two 11” woofers and three 11” sub bass radiators. It has an all passive bass-EQ-Varioterminal, multiple tweeter curve adjustment and a most flexible bass-radiator tuning system to adjust everything perfect to small, medium and big rooms. And of course one can drive it also active with our TIDAL LPX technology.
     Specifications:
      · Floorstanding reference loudspeaker
      · 1 x 30 mm (1.2”) pure diamond tweeter, decoupled metal alloy housing
      · 2 x 173 mm (7”) mm BCC (Black Coated Ceramic) midrange woofer, hand polished aluminum
      clamp ring with curve shape to reflexions from the diaphragm protection grill
      · 2 x 280 mm sandwich-compound woofer
      · 3 x 280 mm sub-bass radiator, removable massive aluminum clamp system, adjustable with
      several different weights
      · TIRALIT ™ multi chamber cabinet
      · Active/passive bass driver CIC-configuration
      · multi adjustment Varioterminal: tweeter curve, deep bass, upper bass, bass level
      · TIDAL Unopulse crossover
      · Optional: SE-version with all pure silver PIO Cast parts
      · Optional: TIDAL LPX active crossover (or with LPX-Module in our reference power amplifier
       TIDAL Impulse
      · Hand polished black piano lacquer
      · Optional: hand polished noble veneers under transparent piano lacquer
      · Isolator system out of massive aluminum triggers and stainless steel isolation platforms
      · incl. ATA-Flightcases
      · Dimensions: 31cm (W) x 60 cm (D) x 169 cm (H)
      · Impedance: 4 ohm
      · Weight: 205 kg (450 lbs.) each, shipment pair 470 Kg (1.030 lbs.)
  2. The Following 3 Users Say Thank You to cica zhou For This Useful Post:
