TIDAL Agoria
第一對使用最新研發的箱體材料:TIRALITTM,也是第一對使用獨家Sunray-CIC技術設計兩顆11吋低音與三顆超低音散熱器。全被動式低音-EQ-Variotermianl、多重高音曲線調整以及超彈性低音散熱調節系統,適合大、中、小的房間。當然也可使永TIDAL LPX技術主動式驅動....
The TIDAL Agoria It is the first speaker with our all new developed cabinet material:TIRALIT ™. The first one with our exclusive Sunray-CIC technology designed with two 11” woofers and three 11” sub bass radiators. It has an all passive bass-EQ-Varioterminal, multiple tweeter curve adjustment and a most flexible bass-radiator tuning system to adjust everything perfect to small, medium and big rooms. And of course one can drive it also active with our TIDAL LPX technology.
Specifications:
· Floorstanding reference loudspeaker
· 1 x 30 mm (1.2”) pure diamond tweeter, decoupled metal alloy housing
· 2 x 173 mm (7”) mm BCC (Black Coated Ceramic) midrange woofer, hand polished aluminum
clamp ring with curve shape to reflexions from the diaphragm protection grill
· 2 x 280 mm sandwich-compound woofer
· 3 x 280 mm sub-bass radiator, removable massive aluminum clamp system, adjustable with
several different weights
· TIRALIT ™ multi chamber cabinet
· Active/passive bass driver CIC-configuration
· multi adjustment Varioterminal: tweeter curve, deep bass, upper bass, bass level
· TIDAL Unopulse crossover
· Optional: SE-version with all pure silver PIO Cast parts
· Optional: TIDAL LPX active crossover (or with LPX-Module in our reference power amplifier
TIDAL Impulse
· Hand polished black piano lacquer
· Optional: hand polished noble veneers under transparent piano lacquer
· Isolator system out of massive aluminum triggers and stainless steel isolation platforms
· incl. ATA-Flightcases
· Dimensions: 31cm (W) x 60 cm (D) x 169 cm (H)
· Impedance: 4 ohm
· Weight: 205 kg (450 lbs.) each, shipment pair 470 Kg (1.030 lbs.)
The Following 3 Users Say Thank You to cica zhou For This Useful Post:
