GOLDMUND Blu-ray Metis 30
可以播放藍光、DVD、AVCHD、SACD...... 原來光碟有那麼多種!!
輸出分為
類比輸出:左右立體聲道
數位輸出:同軸、光纖
HDMI輸出:最高可達7.1聲道高解析PCM訊源、5.1聲道則為DSD、位元流與LPCM等‧‧‧
聲音轉換則是使用杜比系統。
COMPATIBILITY
•BD-VIDEO, DVD-Video, DVD-Audio, AVCHD, SACD, CD, HDCD, Kodak Picture CD,
CD-R/RW, DVD±R/RW, DVD±R DL, BD-R/RE BD Profile:
•BD-ROM Version 2.4 (also compatible with Profile 1 Version 1.0 and 1.1)
OUTPUT
•Analog Audio: stereo Right & Left
•Digital Audio: Coaxial, Optical.
•HDMI Audio: Stereo, up to 7.1ch high-resolution PCM, up to 5.1ch DSD, bitstream or LPCM
conversion of Dolby Digital, Dolby Digital Plus, Dolby TrueHD
•DTS, DTS-HD High Resolution Audio, and DTS-HD Master Audio.
•Digital Video: HDMI with HDCP (NTSC480i/480p/INPUT
•External IR Remote Control
AUDIO CHARACTERISTICS
•Frequency: 20Hz – 20kHz (-0.3 ±0.05dB)
•Signal-to-Noise Ratio: >110dB (A-weighted)
•THD+N: < 0.002% (1kHz at 0dBFS, 20kHz LPF)
POWER
•Power Supply: ‾ 100V – 240V, 50/60Hz AC
•Power Consumption: 35W (0.5W Standby)
SIZE AND WEIGHT
•440 W x 300 H x 70 D (mm). 5.5 kg.
WARRANTY
•3 years, parts and labor.
The Following 4 Users Say Thank You to cica zhou For This Useful Post:
