顯示結果從 1 到 1 共計 1 條
    預設 GOLDMUND Blu-ray Metis 30
    可以播放藍光、DVD、AVCHD、SACD...... 原來光碟有那麼多種!!
    輸出分為
    類比輸出:左右立體聲道
    數位輸出:同軸、光纖
    HDMI輸出:最高可達7.1聲道高解析PCM訊源、5.1聲道則為DSD、位元流與LPCM等‧‧‧
    聲音轉換則是使用杜比系統。
    COMPATIBILITY
       •BD-VIDEO, DVD-Video, DVD-Audio, AVCHD, SACD, CD, HDCD, Kodak Picture CD,
       CD-R/RW, DVD±R/RW, DVD±R DL, BD-R/RE BD Profile:
       •BD-ROM Version 2.4 (also compatible with Profile 1 Version 1.0 and 1.1)
      OUTPUT
       •Analog Audio: stereo Right & Left
       •Digital Audio: Coaxial, Optical.
       •HDMI Audio: Stereo, up to 7.1ch high-resolution PCM, up to 5.1ch DSD, bitstream or LPCM
    conversion of Dolby Digital, Dolby Digital Plus, Dolby TrueHD
       •DTS, DTS-HD High Resolution Audio, and DTS-HD Master Audio.
       •Digital Video: HDMI with HDCP (NTSC480i/480p/INPUT
       •External IR Remote Control
      AUDIO CHARACTERISTICS
       •Frequency: 20Hz – 20kHz (-0.3 ±0.05dB)
       •Signal-to-Noise Ratio: >110dB (A-weighted)
       •THD+N: < 0.002% (1kHz at 0dBFS, 20kHz LPF)
      POWER
       •Power Supply: ‾ 100V – 240V, 50/60Hz AC
       •Power Consumption: 35W (0.5W Standby)
      SIZE AND WEIGHT
       •440 W x 300 H x 70 D (mm). 5.5 kg.
      WARRANTY
       •3 years, parts and labor.
  2. The Following 4 Users Say Thank You to cica zhou For This Useful Post:
