第108頁,共377頁 第一第一 ... 85898106107108109110118158208 ... 最後最後
顯示結果從 1,071 到 1,080 共計 3769 條
  1. #1071
    『系統透明度』略勝黃大的大號角?這個叫我脫褲子也不信,就算換上了鑽石高音我也不信,除非是使用你的DIY前級去欺負黃大那台三萬元的台製綜擴......但是『透明度』是全頻段的,超低頻的音質不正確,一定會毀掉高頻的透明度;你的喇叭在那種空間怎麼可能有正確音質的超低頻?我才不信,等我拿唱片去測試再說.....
    這個明天是星期天嗎?這是基督徒不能輕易動彈的日子,換個時間啦!月童想要來看看我們這些科學瘋子怎麼吵架..... :P :P
    讓您意外到差點吐血:(
    忘了帶那張超圓潤鋼琴
  2. #1072
    引用 作者: rendzaw 查看文章
    讓您意外到差點吐血:(
    忘了帶那張超圓潤鋼琴
    到底有多麼意外?....:P :P
    最近把『絕對VTA』密技消化之後,拿一個重達2克的塑膠,再加上直接測量約0.05克的小紙團,兩個通通放在唱頭蓋上。粗調用2克的,微調用0.05克的,還沒換 sl-1200 之前,先這樣子加減用....
    咦?sl-1200的唱臂與調整座都沒有單賣的嗎?...:^) :^)
  3. #1073
    到底有多麼意外?....:P :P
    曾經看過,臨時搜尋不到:)
  4. #1074
    scs 訪客
    到底有多麼意外?....:P :P
    隨便一張濫片音場都超出喇叭還有深度包刮你以前說音場縮成一團的柯岡布拉母斯小協,我們家低頻到26HZ才明顯衰減,這是儀器測的,前天他們來踢館時方位角沒調的很準有點偏右,修正後現在聲音更完整,加上換了八顆超級電容剛上電就可聽出他的潛力,這是我家超低音跟主喇叭的銜接圖,超級完美.......
  5. #1075
    引用 作者: scs 查看文章
    再升級鑽石更.........:P:P:O
  6. #1076
    我正在為了批改600份期中作業而忙昏了,等我忙完再去狠狠吐你們的槽...
    不過在此之前,請幫我找一台便宜的二手SL-1200,我要好好學習絕對VTA神功....:P :P 不然我只好狠下心來買全新的....:(
    最後,你們不要到處說SL-1200很好啦!這句話根本有問題,因為『它的好』有太多條件限制,講了等於沒講。只有在我這裡認同了超低針壓與絕對VTA兩大密技後,才可以理性地承認SL-1200真的很好。否則,SL-1200本來就是一台很普通的LP轉盤...:P
  7. #1077
    scs 訪客
    沒用輕針壓的SL1200是便宜盤但絕不是什麼爛盤......:o:o:o黃大那個鑽石喇叭現在我這裡操,除了高音還有點緊中低頻差不多了很猛............
  8. #1078
    1200要停產了
    While perhaps not 'audiophile', those who have tried the Technics SL-1200 turntable have generally came away impressed for the money and it has been reported that sales of this legend is coming to an end. A sad day as word on the street is that Technics has stopped making these jewels after producing well over 3,000,000 units since its introduction in 1972 and many evolutions and variants over the years. From Wikipedia, "The Technics SL-1200 is a series of turntables manufactured since October 1972 by Matsushita under the brand name of Technics. Originally released as a high fidelity consumer record player, it quickly became adopted among radio and club disc jockeys. Since its release in 1978, SL-1200MK2 and its successors have been the most common turntable for DJ'ing and scratching. The MK2 presented several improvements, including to the motor and casing. Since 1972, more than 3 million units have been sold. It is widely regarded as one of the most durable and reliable turntables ever produced." This turntable in its most recent generation features a magnetic (no wear) direct drive (low slip) mechanism, high torque of 1.5 kgf·cm (0.15 N·m), which means the platter will spin at the desired speed within 0.7 seconds to reach 33.3 rpm from standstill. Very low wow and flutter of 0.01 percent so that the platter will stay within 1/100 of 1 percent of the desired speed. A heavy base of over 27 lbs aid in reducing the likelihood of feedback or stylus jumping. There is also a variable pitch control so users may adjust the speed -8 to +8 percent, which DJs used for beat matching. Even after many years of DJ use, the Technics SL-1200 has proven reliability. As a ex-DJ myself, have personally used these during gigs and am right debating buying a new pair for future use.
  9. #1079
    1200要停產了
    救命啊!那現在還有沒有新品兩萬元以下,可以邊聽邊調vta的LP轉盤+唱臂?好像 STANTON STR8-100 也是?但是它多了一個LINE輸出,感覺就是會污染音質的樣子...?
  10. #1080
