顯示結果從 1 到 1 共計 1 條
    預設 Bryston Adds Power and Performance to Flagship Integrated Amplifier
    旗艦級綜合擴大機,基本版建議售價 USD4,695;並可選購DAC USD1,395與動磁唱盤放大USD600。
    Peterborough, Ontario April 4th, 2012— Bryston LTD, builders of the world’s finest audio electronics and celebrating 50 years in 2012, has announced the introduction of the B-135 SST² integrated amplifier, replacement for the company’s legendary B-100 model that has been available in the Bryston lineup for over 7 years. The new B-135 SST² delivers 135 watts per channel into 8-Ohms and employs Bryston’s most advanced analog circuitry in the preamp section, providing audio aficionados with an ultimate performance solution in a compact chassis. The B-135 SST² adds features and performance while retaining the same MSRP as the B-100—$4695 in its base configuration. Customers can choose to add the optional onboard DAC for an additional $1395 and the optional moving magnet phono stage for an additional $600. The Bryston B-135 SST² is expected to ship to authorized dealers in May, 2012.
    The Bryston B-135 SST² includes provisions for 7 high level inputs, a pass-through feature (typically for home theater applications), one tape loop and a pre-out/main-in feature. A front panel headphone jack is standard and a full featured remote control is optional. Exceptional performance is derived from the use of three completely independent custom torodial power supplies engineered to prevent any possibility of channel to channel cross talk, interference or interaction between digital and analog sections. Bryston’s proprietary ultra-linear input buffer results in the lowest possible noise floor and miniscule distortion levels.
    The B-135’s pass-through feature and pre-out/main-in connectors allow for complete separation of the preamplifier and power amplifier sections, making multi-channel system integration quick and easy. Gold plated five-way speaker binding posts and gold plated RCA/SPDIF input and output connectors provide long-term trouble-free connections. “The B-135 SST² delivers the performance of separate amplifier and preamplifier combinations from a single, handsome compact chassis,” explained Bryston’s James Tanner. Sonically, the B-135 is the finest integrated amplifier ever offered by Bryston and it is versatile as well—able to address the needs of any audiophile listener with completely separate amp and preamp sections as well as an optional DAC and phono stage. The B-135 is the complete package,” Tanner added.
    Bryston B-135 SST² Features:
    -135 watts per channel 8 ohms / 180 watts per channel 4 ohms
    -Over 30,000 MFD of filter capacitance per channel
    -Three new ultra-low-noise power transformers - two for analog circuits, one for digital circuits
    -Totally separate ground paths for digital and analog sections
    -New computer-modeled heat-sink design
    -Two quick-connect 12 Volt output triggers – (one programmable)
    -New digitally controlled analog volume dial
    -Full function BR2 remote (optional)
    -4 assignable digital inputs
    -R232 control and software upgradable
    -IR control
    -Headphone jack (front panel)
    -Two optical and two SPDIF inputs
    -Optional Internal phono stage (moving magnet)
    -Optional Internal DAC (Digital to Analog Converter)
    -20 Year Warranty
    http://www.bryston.com/
    此篇文章於 2012-04-20 11:40 AM 被 cica zhou 編輯。
  2. The Following 2 Users Say Thank You to cica zhou For This Useful Post:
