Stahl~Tek Audiophile Bridge to Computer
Stahl~Tek發表了一台與電腦連接的介面,非同步USB 2.0支援到24/192,售價約USD 3,500
$3500
The A.B.C. streams bit perfect audio data up to 24-bit @ 192kHz, providing a signal clear, and true to its source. The A.B.C. will output true, 24-bit audio files and supports all these sample rates: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz.
The A.B.C. is finely designed to work within your digital system. Your digital system will function together as parts of an instrument. Your A.B.C. is built to fit effortlessly into your system, becoming a “bridge” between your computer and your DAC.
Features
Streams bit perfect audio data up to 24-bit @ 192kHz
USB 2.0 High Speed 480 Mb/s Computer Interface
Supported Sampling Rates: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
Supports true 24-bit audio files
Full galvanic isolation of all outputs
USB audio synchronization endpoint operates in the asynchronous mode
Internal master clock circuitry lowers the jitter operation of the USB endpoint and serves as a master clock signal through the I2S output port to a DAC
I2S Stahl~Tek HDMI input provides an addition signal input for the optional Stahl~Tek Opus/Vekian CD Transport, thus allowing the ABC Bridge to serve as a convenient digital source selection to any Stahl~Tek DAC (PS Audio also supports this unique, high-end interface)
USB 2.0 audio is built into Apples OS X, Version 10.6.3 and Windows XP and Windows 7 support is via supplied, custom drivers
Compatible with WDM/Direct X and ASIO 2.1
Works with your preferred media player, such as: J-Rivers Media Center 16 and 17, Foobar 2000, MediaMonkey, among others
Technical Specifications
Power Supply 5.0V DC
Digital Inputs
I2S Stahl~Tek HDMI (also works with PS Audio)
Asynchronous USB 2.0 (480 Mb/s, Backwards compatible to 1.0)
Sampling Input/Output Frequencies 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
Digital Outputs BNC RCA AES/EBU I2S
Dimensions Size: 17" x 7.25" x 2.75" Weight: 4 lbs.
http://www.stahltek.com/
The Following User Says Thank You to cica zhou For This Useful Post:
