第2頁,共21頁 第一第一 123412 ... 最後最後
顯示結果從 11 到 20 共計 203 條
  3. #12
    Vivid Audio Switzerland have officially opened their showrooms. Thank you to Robert Trunz for sending in this frankly awesome shot of the G2 Giyas on demonstration. Excellent!
  4. #13
    The main display was allocated to the G1's however, with Gryphon supplying the amplification et al. Thank you very much to Radim at RP Audio for putting on a great demonstration, and supplying the photos!
  5. #14
    沒想到單獨看會覺得長很奇怪的B1在這樣的空間中還蠻能融入畫面的
    Check out http://www.prisjakt.nu/produkt.php?g=443825 for more images of Pearl B1's in this modern home.
  6. #15
    那對G1的顏色好屌!
  8. #17
  9. #18
  10. #19
  11. #20
    G3 新包裝
    Here's an image of the CAD model used to design the packaging. Every nut and bolt (and washer) is modeled so that we can be 100% certain that everything will go together as planned.
    裝箱模擬圖,螺帽與螺栓都已經做好了,所以可以確定如Vivid Audio所計畫的運送囉!!
    The G3 packed in its non-scratch bag. The accessories (spikes, jumpers, grilles and so on), are boxed and placed in the gaps you can see. Cramming everything that needs to be in the crate while ensuring the safety of the speaker was a task in itself!
    G3用布袋包起來了,所以不會有刮傷的問題。配件都放在一個盒子裡,並放在設計的縫縫中.....
    This is the completed CNC cut lower packaging for a G3. The white ring at the bottom is there to support the C135 bass driver. This is necessary as the drivers are not rigidly attached to the cabinet, but are fastened only to each-other and literally float on silicone decoupling O-rings within the cabinet. Without propor support they can shift (as a pair) relative to the cabinet as it is bumped and knocked during international shipping.
    這是外包箱內部的底部,白色圈圈是保護C135低音單體的唷!!
  12. The Following 4 Users Say Thank You to cica zhou For This Useful Post:
