【喇叭】加拿大 VERITY AUDIO SARASTRO II
規格:
Bandwidth: 20 to 60,000 Hz ± 3dBWoofer: 11“ (280 mm) doped polypropylene 4“ (100 mm) SD-1 high-power underhung motorMidrange1: 6“ (150 mm) doped polypropylene 2“ (50 mm) SD-1 high-power underhung motorTweeter: 2“ (50 mm) pure aluminum ribbonInput Power: 7 watts ( 8 Ω ) minimum recommendedSensitivity: 93 dB @ 2.83 Vrms & 1 meter on axisImpedance: 8 Ω nominal, 4 Ω minimal
Dimensions & Weights
W x D x H: 14.0 x 20.0 x 47.5“ (350 x 505 x 1,210 mm)
Weight : 300 lbs (136 kg) 470 lbs (214 kg) packed / pair
CA BINET FINISH
Standard: High-Gloss Piano Black
Special Order: High-Gloss Silver, Makore & Quilted Big Leaf Maple
FEATURES & ACCESSORIES
Connectors1: Gold-plated 。removable posts
Isolation Cone1: Solid brass with stainless steel lockable spikes
Isolation Platform : 1-1/4“ (32 mm) Damped Aluminum
Jumper Cables : 8“ (203 mm) high purity copper
Transportation Case : ATA “Air Transportation Association” metal case
此篇文章於 2012-03-07 11:51 PM 被 kib 編輯。
虛空有時盡 我願仍無窮
The Following 3 Users Say Thank You to kib For This Useful Post:
虛空有時盡 我願仍無窮
虛空有時盡 我願仍無窮
虛空有時盡 我願仍無窮
虛空有時盡 我願仍無窮
虛空有時盡 我願仍無窮
The Following User Says Thank You to kib For This Useful Post:
SARASTRO 和 SARASTRO II 兩者可見的最大差異為, SARASTRO 兩箱體間所墊的是石材, SARASTRO II 是類似 HRS 般的多重複合材質, 聲音更好.....
虛空有時盡 我願仍無窮
The Following 2 Users Say Thank You to kib For This Useful Post:
高音單體為VERITY AUDIO自制的鋁帶高音, 頻寬可達 60KHz
虛空有時盡 我願仍無窮
虛空有時盡 我願仍無窮
虛空有時盡 我願仍無窮
