顯示結果從 1 到 4 共計 4 條
    預設 Burmester new 113 D/A Conveter incl. Bluetooth and USB input
    數位流的趨勢似乎在Hi-End廠家上, 也不得不跟進了
    http://www.burmester.de/en/index.php
    The Burmester 113 D/A converter was designed in the course of developing the MMI
    module for our 061, 069 and 089 CD player models. The result is an independent D/A
    converter with maximum high-end quality, which not only features electrical and
    optical digital inputs but also supports wireless data transmission. The 113 has two
    digital inputs and two analogue outputs, as well as a Bluetooth® (even supporting
    aptX® codec for best sound quality via Bluetooth® ) and a USB input (class 2 audio) to
    ensure that you can enjoy all of your digital music sources in the best-possible audio
    quality. Moreover, the 113 contains balanced circuitry, with a fully DC-coupled signal
    path and no coupling capacitors getting in the way of the signal. The sophisticated
    analogue output stages obtain their signal from a converter stage of the latest
    generation, with switchable sampling rates (48kHz, 96kHz and 192kHz) to guarantee a
    highly defined and musical sound.
    In addition to the outstanding audio quality resulting from the D/A conversion, the 113 DAC
    features comfortable wireless integration of all audio sources equipped with A2DP
    (Advanced Audio Distribution Profile) into an existing system. The 113 then functions as a
    Bluetooth® receiver and music is transmitted to the system by connecting a laptop,
    microphone, etc. to the Bluetooth® interface.
    虛空有時盡 我願仍無窮
    虛空有時盡 我願仍無窮
    Music stored on an iPhone®, Blackberry® or other mobile telephone device can now be
    played back through the system via a wireless connection. This feature is extremely useful
    for ensuring uncomplicated and spontaneous music enjoyment in any situation.
    In order to achieve maximum sound quality with the limited bandwidth of a Bluetooth®
    connection, the 113 DAC supports the aptX® codec. Of course it is also possible to connect
    your computer to the 113 D/A converter via its USB interface. A USB connection supports
    the lossless transfer of uncompressed data, and therefore promises audio reproduction of
    the highest quality.
    Features:
    • Upsampling of all digital audio signals switchable between 48kHz/24 bit, 96kHz/24 bit
      and 192kHz/24 bit
    • Phase reversal of 180° available at output
    • Bluetooth® SBC & aptX® codecs
    • USB input to allow connection of a computer:
    • o Class1audiowithupto96kHz/24bit
    • o Class2audiowithupto192kHz/24bit
    • Trusted Burmester reference converter technology with balanced conversion
    • Fully DC-coupled signal path with no coupling capacitors in the way of the signal, for
      precise bass reproduction with no phase shift in the audible spectrum
    • “Green“ power supply with a very low, environmentally-friendly power consumption of
    • less than 1W in standby mode
    • Galvanic isolation between the analogue and digital sections
      Connections:
      Digital inputs
    • 1xRCA
    • 1xTOSLINK
    • 1xUSB
    • 1x Bluetooth®
      Digital outputs
    • 1x RCA
    • 1x TOSLINK
      Analogue outputs
    • 1x RCA stereo
    • 1x XLR stereo
      Technical Specifications:
      Dimensions (W x H x D)
    • 200 x 60 x 165 mm
    • 7.9” x 2.4 x 6.5”
      WEIGHT
    • 1.5 kg
    • 3.3 lbs
    虛空有時盡 我願仍無窮
    Burmester 113承襲了061, 069與089 CD唱盤的精華設計,不但有傳統的的數位介面,還有24/192 USB (Class 2)與藍芽無線傳輸,並使用平衡線路設計,還48kHz、96kHz與192kHz的升頻選擇。令外還有輸出180度向位反轉的選擇。
