第550頁,共715頁 第一第一 ... 50450500540548549550551552560600650 ... 最後最後
顯示結果從 5,491 到 5,500 共計 7148 條
  1. #5491
    引用 作者: gangster.tank 查看文章
    沒理解錯的話,是想要用Ian's FIFO來傳輸RIP後的檔案?讓檔案通過高品質的時鐘重新生成儲存?
    目的是基於兩大重點,其一是 RIP 方面的準備功夫並非那麼簡單,例如這些影片(聽不懂的話敬請開啟中文字幕,謝謝)中提及的步驟,到底是魔鬼在於細節還是龜毛細節亦有待商榷,假如 Ian's FIFO 的能力可以令所有工序變得無關痛癢就太棒了:
    https://www.hiendy.com/?p=12067
    https://www.hiendy.com/?p=12101
    其二是關於 CD 表面的染料層,畢竟那是物理方面的差異,例如 UHQCD 甚至天價的玻璃 CD 就有先天性的優勢,另外還有拷貝後比原版光碟片更上一層樓的案例,就是 RIP 普通 CD 之後用三菱 Green Tune 燒錄片加上 Yamaha CRW-F1 或 Plextor Premium 再燒錄 AMQR 格式的說,而最後 AMQR 格式的 Green Tune 版本竟然比原版的玻璃 CD 有過之而無不及:
    http://aqcd.org/main/index.php?main_page=page&id=1
    http://aqcd.org/main/index.php?main_page=page&id=2
    http://www.erji.net/forum.php?mod=vi...ad&tid=1241049
    http://www.erji.net/forum.php?mod=vi...ad&tid=2153111
    http://www.genesisloudspeakers.com/w...ate.pdf#page=3
    https://www.whatsbestforum.com/threa...16#post-219732
    3. River of Sorrow – Crystal disc
    4. My Crystal disc remaster on Green Tune disc
    Just out of the Redbook CD’s, there was 1 person that thought Disc 3 and 4 were tied for the best. Two people though thought that Disc 4 was more pleasurable to listen to over a long period of time and the other 2 people thought Disc 1 was better over a long period of time, but then chose Disc 4 on another track that was played.
    Green Tune 燒錄片的售價也相當可觀,一片要 8 鎂,20 片就 140 鎂,100 片也要 600 鎂,由於 CD-R 只可以燒錄一次,因此才祈求 Ian's FIFO 能夠帶來一點喜訊,當然物理方面的差異就不知道結果如何了。
    此外行動電源可能是屬於未知之數,它們的 ripple 好像並非那麼理想,而且 switching regulators 跟 Ian's FIFO DAC 的 linear power 也許有點兒水火不容:
    https://goughlui.com/category/power-bank-2/
    https://audiophilestyle.com/forums/t...comment-876256
    FWIW, most people don't realize that these USB batteries and power banks use DC-to-DC boost converters internally (a switch mode power supply) to achieve various voltages from their internal lithium-ion batteries.
    https://audiophilestyle.com/forums/t...comment-590557
    It gets a switching regulator (same for a lot of 5v phone power bank), and what you are going to do is just replace the dirty digital noise from your network with a "clean" digital noise from your tp link supply.
    電腦棒也好,NUC 也好,所有主機板的穩壓方面也是 switching regulators 的天下,選擇不多的時候就只有 Ian's LiFePO4 MkIII 跟這種特殊主機板的『全線性』方案了:
    https://www.diyaudio.com/forums/powe...ml#post5540295
    https://www.allo.com/sparky/usbridge-signature-pcb.html
    To lower the noise of the USB, we had to lower noise on EACH rail. In total, USBridge Sig uses more than 30 LDOs. Even the SD card power rail has a dedicated LDO. There are zero switching elements on board.
  2. The Following 10 Users Say Thank You to seeteeyou For This Useful Post:
  3. #5492
    預設 Ian's FIFO DAC解開封印
    小弟在昨天跟bchsieh兄請教了一些DAC的基板共地的問題。
    在bchsieh兄的提醒之下,小弟拿出電表測量dirty side和clean side的基板GND是否有相連。
    結果出乎意料之外的dirty side和clean side基板上的GND居然有相連!!
    在小弟檢查線路後發現clean side的MUTE基板和dirty side的基板是由同一片LT3045穩壓基板來供電的。
    在移除MUTE基板的電源接頭再次使用電表測量後,dirty side和clean side的GND就確定完全的隔離了。
    之後小弟暫時先從clean side的McDualXO基板的5V電源上,另外拉了兩條裸線來供電給MUTE基板使用。
    在確實將dirty side和clean side的GND隔離之後,小弟猜想之前CD RIP的差異無法完全消除可能也是這個原因。
    果不其然小弟今天再重新測試RIP差異比較時,已經幾乎是完全的比較不出不同RIP版本的聲音差異了。之前有位
    網兄私下請我幫忙測試他RIP的出賽曲是否能夠跟狂人比較的版本消除差異。之前我測試後回答他還是有些差異無法
    完全消除,或許是他RIP的CD跟狂人比較RIP的CD不是同一版本才會無法消除差異。不過今天小弟再度測試之後,
    果然那位網兄的RIP版已經跟狂人比較的兩個版本聽不出來差異了。連之前教授請Higuma兄幫忙RIP的SOCD326的
    第6首,現在也已經跟教授的RIP版聽不出甚麼差異了。
    另外在徹底將dirty side和clean side的GND隔離之後,Ian's FIFO DAC的聲音空間分解能力跟樂器合奏效果也跟著
    提升了許多。而且小弟猜想在解除dirty side和clean side的GND共地的問題後,應該連DAC前端數位訊源設備的差異
    也會進一步的被完美消除。
    看來7月12日到中壢教授音響室的DAC PK大對決或許可能勝負還很難說了。
  4. The Following 11 Users Say Thank You to tetsuka For This Useful Post:
  5. #5493
    引用 作者: tetsuka 查看文章
    Hi tetsuka
    我的U3TT只是單機版,雖然也還沒體驗過雙機版的U3TT,但是經過調整,在我的系統上Ian Fifo+TransportPi 已經全面大勝單機U3TT了,而且是『階梯』式的跳躍,音場、聲音的正確性、暫態、餘韻都是完勝。特別的是接老的Dac (PS audio Ultralink)&Dat(Fostex),居然能讓這些老DAC都能回春,展現一拚現代DAC細節與暫態,這倒是令人出乎意料,所以PK大對決或許可能勝負還很難說喔!
    (PS: Dozen 還是要加,我加了聲音結實度差很多)
    此篇文章於 2020-06-29 08:46 PM 被 chinpunto 編輯。
  6. The Following 7 Users Say Thank You to chinpunto For This Useful Post:
  7. #5494
    然後我發現 C13 用的晶片是 SA9227,我在淘寶看到一台DDC是 SAVITevh SA9227 USB控制晶片,使用晶振ACCUSILICON AS318B,賣家在淘寶上面宣稱這顆比CCHD 957更好,感覺挺有趣的,不過看了 Ian's FIFO 要不要再買這台得考慮考慮了,但改DAC真的讓人怕怕的!
    https://item.taobao.com/item.htm?spm...u=t2dmg8j26111
    如果真的此討論串有人開始玩 Ian's FIFO 的話,請務必分享改裝流程給燒友學習之!
    真的有些例子:
    https://www.diyaudio.com/forums/digi...ml#post5795443
    Swapped clocks to Crystek, NDK and Accusilicon
    - Crystek and NDK not a big difference, preferred Crystek slightly
    - Accusilicon imho has a small edge and stays on for now (also easy to try because it is a size for size dry swap with the standard clocks)
    https://www.diyaudio.com/forums/digi...ml#post5796027
    The Accusilicon type i'm using is the DIP14 version of AS318B:
    http://www.accusilicon.com/docs/AS318BM.pdf
    https://www.diyaudio.com/forums/pc-b...ml#post6178357
    The Accusilicon arrived.
    Sounds better to me than the NDK.
    https://www.diyaudio.com/forums/pc-b...ml#post6178939
    Wider, deeper soundstage.
    Let's say, with Accusilicon you are in the first row, with NDK in the second :-)
    https://www.diyaudio.com/forums/pc-b...ml#post5961507
    The Accusilicon 318B I mentioned before, I have confirmed that the Accusilicon 318B crystal is the same level as the CCHD950, and the Accusilicon 318B is less than $1.
    https://www.diyaudio.com/forums/pc-b...ml#post5961710
    For me accusilicon is more better of crystek, when you listen the music, with test on laboratories i don't now
    AS318-B-49.152MHZ
    https://item.taobao.com/item.htm?id=598248892770
    AS318-B-45.1584MHZ
    https://item.taobao.com/item.htm?id=598480545030
    AS318-B-100MHZ
    https://item.taobao.com/item.htm?id=598668754590
    AS318-B-903168 /AS318-B-983040
    https://item.taobao.com/item.htm?id=607577586956
    Jitter 方面該是各有優劣,不過 90 系才能夠對應 352.4kHz/384kHz 的說:
    http://www.accusilicon.com/docs/AS318BM.pdf#page=7
    另外 DIP-14 封裝的好處就是難度較小的安裝。
  8. The Following 7 Users Say Thank You to seeteeyou For This Useful Post:
  9. #5495
    DIP14 是直接可以跟Ian's FIFO上面的clock晶片對換嗎?
    如果可以不要焊那些SMD,那是最好了。
  10. The Following 4 Users Say Thank You to kevintran For This Useful Post:
  11. #5496
    先聲明一下,以下是小弟的偏見:
    關於Accusilicon clock,如果真的比NDK NZ2520SDA好,對大家來說絕對是好消息。
    但是....
    1. YunYun 推薦的東西,小弟第一時間會先抱持懷疑態度。
    2. Accusilicon datasheet上的規格很漂亮(但還是比不上NDK NZ2520SDA的數據),
    但由於是某國投資的公司,所以在第三方測量數據出現之前,請恕小弟也先打個問號。
    3. NDK NZ2520SD 比 NZ2520SDA 差了不少,說Accusilicon比NDK好的人,不知道是跟SD比還是跟SDA比?
    此篇文章於 2020-06-29 11:30 PM 被 bchsieh 編輯。
  12. The Following 8 Users Say Thank You to bchsieh For This Useful Post:
  13. #5497
    引用 作者: chinpunto 查看文章
    Hi tetsuka
    感謝chinpunto兄提供FifoPi使用心得來背書,這也讓小弟對Ian's FIFO DAC的聲音表現更有信心了。
    當然未來小弟的DAC再度升級的時候,就是打算將所有基板的穩壓都換成Dozen。
    話說日本職人為了DAC設計的Dozen mini基板也已經製作完成了,只是目前職人還未開始公開的販售。
    因為DAC使用的基板耗電量都不大,所以職人Dozen mini是改用12顆並聯的LT3042和LT3093來製作。
    照片上方基板左右各有一組12顆並聯的LT3042穩壓,下方是給IV基板用12顆並聯的LT3042和LT3093穩壓。
    目前Dozen mini預計會用在日本音響BLOG主送回給日本職人改裝McFIFO/McDualXO的職人設計的DAC上。
    在職人的建議之下這次的DAC改裝預計會將所有變壓器移到獨立的電源機箱,然後變壓器2次側先使用4並聯
    的LT3045或LT3094穩壓基板作預穩壓之後,再從電源機箱把電源送到DAC機箱的Dozen mini穩壓供電給各基板。
    日本音響BLOG主有跟我提到這次的DAC改裝,預計使用的時鐘跟我使用的NDK NZ2520SDA不一樣。雖然他並沒
    告知我他預計使用哪顆時鐘,不過我猜想他或許可能會直接使用最高檔的DuCULoN。
    當然日本音響BLOG主的DAC在經過這次的升級之後,想必聲音一定會大幅的超越小弟目前的Ian's FIFO DAC。
    小弟也相當期待他的DAC升級完成之後的聲音表現心得,想必應該也能夠當作小弟未來DAC升級時的重大參考。
  14. The Following 10 Users Say Thank You to tetsuka For This Useful Post:
  15. #5498
    引用 作者: tetsuka 查看文章
    tetsuka兄您好,
    就如您所說的,小弟也認為使用Dozen mini應該是會讓聲音更上一層樓。
    但是請恕小弟直言,在數位電路部分如果達人仍然是按照原設計,那麼小弟對使用DuCULoN之後能有多大的提升,其實是抱持著保留的態度。
  16. The Following 5 Users Say Thank You to bchsieh For This Useful Post:
  17. #5499
    tetsuka兄您好,
    小弟猜想bchsieh兄認為使用DuCULoN之後能有的多大的提升的疑慮,是因為I2S訊號會經過中繼基板的關係吧。
    關於中繼基板上的IDT的551SCMGI性能比不上McDualXO上Potato的的超高速晶片(1GHz),所以可能會造成
    McDualXO的時鐘訊號性能劣化這件事小弟之前就已經告知過日本音響BLOG主。因為日本音響BLOG主最近開始
    使用AuI ConverteR 48x44將常聽的PCM音樂檔都轉換為DSD格式,所以他升級後的DAC主要也是用來聆聽DSD。
    所以他的DAC為了穩定播放DSD的話可能還是需要使用中繼基板,就看看日本職人會不會另外想出新的解決方案吧。
    另外請教一下bchsieh兄如果為了播放DSD還是需要中繼基板的話,那麼可以將IDT的551SCMGI更換為和
    Potato的的超高速晶片性能相近的晶片來減少時鐘訊號的劣化嗎?
    如果小弟的想法可行的話,也請bchsieh兄推薦可以取代IDT的551SCMGI的晶片給小弟。謝謝您
  18. The Following 3 Users Say Thank You to tetsuka For This Useful Post:
  19. #5500
    昨天在網路上找NDK NZ2520SDA 的店家,好像很少,而且都是DIY材料供應的網站。像Digikey,Mouser,等等的大公司都沒有;因為好像跟NDK買的量是以3000顆起跳,要是賣的很慢,那些公司大概也不想賣。
    請問大家都是去哪裡買的?SDA比其它SB或是SD都貴了不少,我怕買到假貨。
    先謝謝啦!
  20. The Following 3 Users Say Thank You to kevintran For This Useful Post:
