此篇文章於 2012-11-26 11:56 PM 被 小余 編輯。
W4S mINT超優一體機~加購zonotone 7N USB 與電源線優惠方案實施中!!! 快來跟 心曲音響小魚詢問吧!!!
100W 超好推
DAC的部分很讚...
多功能可以搭配CD、Wi-Fi DAC、當劇院的後級、當純DA、當純前級、當耳擴、接超低音....超多功能結合一體!
此篇文章於 2012-11-29 03:24 PM 被 小余 編輯。
【JPLAY 代購】長期優惠代購,請跟小余聯絡
Full memory-based playback
no disk activity during playback
Most other memory-based players dynamically load tracks into memory during playback. In contrast, jplay pre-loads complete playlist into RAM guaranteeing zero disk I/O during music reproduction.
Maximal Priority Scheduling
ultra low latency capabilities
Ensure uninterrupted flow of music data by running music playback at highest possible priority.
Hibernation Mode
multicore audio playback
Cancel OS ‘noise’ by eliminating dozens of OS jitter-inducing processes & hundreds of threads!
相關資料請參考這
http://www.my-hiend.com/vbb/showthread.php?t=4003
就是High End等級的CAS播放軟體,也可與其他播放軟體相容
只有windows版,且XP不能用
正式版為Euro 99
有意參加團購的朋友請回在版上....
長期代購方式!!!
考量刷卡手續費及作業成本
NTD 3,500 一套 (原價99歐元)
請跟小余聯絡
流程是
1. 回覆在此跟小余確認要代買幾份以及版本
2. 悄悄話給小余,內容請包含你要註冊的英文名及E-mail信箱,並告知要32Bit、64Bit還是兩者都要的JPLAY版本 (注意XP無法使用)
3. 等待小余悄悄話回覆您匯款帳號,請轉帳付款 3,500/份 到小余的帳號,並告知轉出帳戶末五碼
3. 確認收到款項後,小余會通知原廠寄發JPLAY到你的信箱
4. 日後有升級原廠也會直接寄到你的信箱 (免費)
此篇文章於 2012-06-25 01:13 AM 被 小余 編輯。
最夯的W4S,又有超高C/P值的迷你DAC了!!!!
與DAC1同等級的DAC晶片~裝在迷你的航太鋁合金盒子裡,
有同軸、光纖(24/192)、USB(24/96)輸入,RCA輸出。
可選擇由USB或外部9V供電~
價格超殺!!!! 只要 NTD 15,600 ~~~
預計六月到貨!!! 要預購的請快跟小余聯繫~~~
這麼優的東西,只能說...太殺啦....
https://www.facebook.com/events/413580698667049/
可直接站內信跟我聯繫!!!!也可在此或是fb留言登記~~~
感謝!
http://www.wyred4sound.com/webapps/p.../117839/618197
W4S ΜDAC (ΜDAC) - DACS
ALL NEW!! Measuring at just under 3.5"x3.5"x1.25" this DAC will fit almost anywhere!
Now Shipping!Some great customer feedback!"I really like the unit, great imaging, a little warmth, fine bass. I know there are more expensive, maybe better DAC's out there but this is so good that I don't really care. The µDAC is a very nice product that just disappears and does its job. I kind of wish for a remote that I could use to switch inputs but at that price I can't complain. – Thanks"
The Wyred 4 Sound µDAC is the perfect solution for digital streaming made simple. In many cases, the price and overall size of most dedicated DACs deters music enthusiasts from going digital. Whether it be for a second system or to begin digital streaming for the first time, the µDAC can surely impress. There are currently a handful of DACs available with a similar foot print to the µDAC but we have ensured that this piece has more to bring to the table. In fact, after learning about the high resolution support and stellar sonic performance, you may consider making this the go to DAC in your home and or office.
There are two S/PDIF inputs which support 24 bit 192 kHz signals as well as an asynchronous USB input for computer streaming. Any of the inputs will provide the kind of performance expected from a price tag many times higher. From Internet radio to high res streaming the µDAC will not miss a beat. We adopted the very same USB technology used in our DAC-1! We were even able to include an ESS DAC to take full advantage of the limited real-estate in this 3.5”x3.5” chassis.
Not only will the µDAC perform sonically, its soft lines and smooth finish make for a sleek looking product. Made from machined aircraft-grade aluminum with the W4S logo as a lock light (lights up blue when the DAC is locked onto a signal!), the µDAC is very functional yet so simple. Power is fed directly through USB when streaming from a computer. When using the S/PDIF inputs the USB cable is plugged into an outlet using the supplied adapter. Simplify and improve your digital streaming today!
此篇文章於 2012-05-04 12:38 AM 被 小余 編輯。
HRS 專業避震墊材開賣囉!!!
Nimbus 與 Damping Plates 雙種精巧墊材,滿足您器材的避震需求!
雙種墊材開賣囉!!! 有需要的快來登記登記~~~
價格就是*匯率30,與國外售價相同唷!!!
http://www.avisolation.com/nimbus.html
http://www.avisolation.com/damping_plate.html
此篇文章於 2013-01-23 08:35 PM 被 小余 編輯。
Glad Rag Doll (Deluxe Edition) 24/96 代買開始囉!!!
需要幫忙買的快來跟小魚說!!! (折合台幣650)
這邊可以試聽
https://www.hdtracks.com/index.php?f...00602537153725
此篇文章於 2012-10-02 02:52 PM 被 小余 編輯。
Resolution Audio- The Cantata Music Center
http://www.resolutionaudio.com/
For over a decade, Resolution Audio has received praise for its meticulous attention to detail in creating highly-acclaimed stereo components.
The guiding philosophy behind the company has always been to build stereo components which deliver accurate and engaging musical reproduction at a reasonable price.
We build each component to order and test every unit personally before we ship them to our customers.
Our approach doesn’t allow us to make or sell as many units as other companies do every year; however, our satisfied customers assure us that our approach is well worth it.
Multiple sources, zero compromises
The Resolution Audio Cantata Music Center serves as the digital hub in a high-end audio system providing the same audio performance regardless of the input source.
Whether it’s a CD played via the built-in transport, an uncompressed iTunes library stored on a Mac or Windows computer, or a dedicated music library on a network storage system (NAS),
the Cantata Music Center will play every note as if it were from the original CD.
To a host computer, the Music Center “looks” like a standard USB audio device which both Mac and Windows operating systems support natively.
While USB connections are physically limited to 15 feet, theResolution Audio "Pont Neuf" creates a "virtual" USB connection directly to the Music Center via ethernet cable or through your
wired or wireless home network. In either case, no additional software or drivers are required.
Because the Music Center utilizes a computer-based music library, it doesn't rely on a proprietary means of storing your CD data.
Any software can be used for ripping and any software can be used for playback.
The music library is safer since the storage can be easily backed up to a second drive or protected from loss using “RAID” technology, and capacity can be easily increased by adding off-the-shelf hard drives.
With no hard drive located within the Music Center itself, the device remains completely silent and free of vibration. You choose where the library is stored, how it is backed-up,
and what software is used to play it.The Cantata Music Center and C50 integrated amplifier are controllable from an iPad, iPhone, or iPod Touch via the Cantata App.
Other digital sources such as a DVD player can be played through the external inputs. (See example configurations diagrams below.)
Based on the award-winning Opus 21 series, the Cantata design has been further refined and optimized for the emergence of computer-based music libraries.
Built for simple integration into popular sources, the Cantata's modular architecture will accommodate tomorrow's formats and beyond.
Features:
- NEW! USB up to 192kHz / 24-bit using asynchronous mode
- Slot-loading compact disc drive
- Ethernet link for iTunes (via the Resolution Audio Pont Neuf) and UPnP libraries*
- Digital S/PDIF inputs (AES/EBU, RCA, Toslink)
- XLR and RCA outputs, fixed or variable
- iPhone/iPod Touch remote control interface
- 43 x 23 x 5 cm (17 x 9 x 2")
- 6 kg, (13 lbs.)
此篇文章於 2013-04-23 11:39 PM 被 小余 編輯。
【每日推薦專輯試聽區】
僅供串流試聽 曲目長度只有一半 喜歡請點擊專輯封面購買數位專輯!!!
【如有任何侵權行為將立即停止提供試聽】
串流試聽說明:
1. 電腦請先下載安裝![]()
就能在瀏覽器中串流影音直接播放 就不用把檔案整個下載到電腦中
2. iPhone與iPad無法播放高音質版本是正常的 因為iDevice僅支援16bits/44.1kHz請改聽wav檔版本
3. 喜歡這張專輯 卻不知如何購買與轉檔的朋友 有需要代購+轉檔成需要的格式的可以pm給我 小魚幫你們處理
小魚推薦勸敗區-可代購&轉檔 (點擊封面取得專輯相關資訊)
....持續增加推薦中
【2012/02/27 推薦專輯:教堂之音 CANTATE DOMINO】
CANTATE DOMINO / Bossi: Cantate Domino 24bits/88kHz AIFF檔串流試聽Title: CANTATE DOMINO
Artist: Marianne Mellnas / Alf Linder / Oscar's Motet Choir / Torsten Nilsson
Genre: Classical
Label: Proprius
Release Date: 2005
CANTATE DOMINO / Bossi: Cantate Domino 16bits/44.1kHz wav檔串流試聽
CANTATE DOMINO是PROPRIUS公司在1976年錄製的一張聖誕音樂合唱專輯。
聆聽這張唱片,你閉著眼睛只用耳朵,就能輕而易舉的識別出,女高音就活生生的站在音場正中,
她身後弧形站著三排大約30人左右的合唱隊,而伴奏的管風琴位於最後一排,它的高頻居高臨下,
而低頻卻貼地而行……整個舞台都盡收耳底!
這張CD裡那15首聖誕音樂作品的演唱水平之高,根本不是語言所能夠形容的,那無與倫比的神聖和純淨,
簡直到了叫人難以置信的程度。
堂音豐富,空間感絕佳,人聲平衡,定位清晰,被譽為「數人頭」工作。
音響發燒友的CD架上不能沒有這張發燒碟,如果已經有收藏的發燒友,
也不能錯過高解析母帶的版本,絕對又是一番不同的體驗!
HDtracks上能購買到24/88 Flac檔案~
如果不知道怎麼購買的或是需要轉成Aiff檔的,
請悄悄話與我聯繫^^
【2012/02/02 推薦專輯:The Koln Concert】
Koln, January 24, 1975, Part I 16bits/44.1kHz wav檔串流試聽Title: The Koln Concert
Artist: Keith Jarrett
Genre: Jazz
Label: ECM
Release Date: 1975
Koln, January 24, 1975, Part I 24bits/96kHz AIFF檔串流試聽
「科隆音樂會」是爵士樂迷的荒島唱片,也是千萬聽眾瘋狂喜愛的名盤。
The Koln Concert至今依然是爵士音樂史上最暢銷獨奏專輯,也是音樂史上不分樂派、最暢銷鋼琴獨奏專輯。
重點是,這是一張演奏之前沒有任何樂譜依據,完全即興演出的鋼琴獨奏現場演出。
「科隆音樂會相關資訊」
擷取的片段為PartI的中間片段,曲中會有Keith Jarrett隨著演出的哼唱,即興的表現可見其投入在音樂中的深度...
【2012/01/22 推薦專輯:Retrospective】
Retrospective- Auld Lang Syne / Bring It On Home To Me 24bits/96kHz AIFF檔串流試聽Title: Retrospective
Artist: Rebecca Pidgeon
Genre: Jazz / Vocal
Label: Chesky Records
Release Date: 2003
Retrospective- Auld Lang Syne / Bring It On Home To Me 16bits/44.1kHz wav檔串流試聽
這是小魚最愛的民謠歌手 Rebecca Pidgen 所推出的精選輯 當初小魚買的SACD因為製片品質差 早已毀損...
現在改用數位母帶音樂來保存 能收藏永久^^
Auld Lang Syne/Bring It On Home To Me
這首歌聽起來像是我們耳熟能詳的驪歌
也是電影魂斷藍橋的主題曲~
Rebecca將這首歌與Sam Cooke的藍調名曲"Bring It On Home To Me"揉合而成她獨特的蘇式民謠
再加上她的夫婿大衛將Robert Burns的名詩改寫為一開始的吟誦篇章
中段又由樂器的獨奏來表現奔放的情感...
算是小魚聽過的改寫歌曲中 融合的最巧妙與感人的了!
今天是除夕夜~~~ 用這首歌帶給大家~盼望各位與朋友之間友誼長存~
揮別兔年 迎向飛黃騰達的龍年!!!
【2012/01/20 推薦專輯:A Treasury of Favorite Violin Encores】
A Treasury of Favorite Violin Encores- Humoresque 16bits/44.1kHz AIFF檔串流試聽Title: A Treasury of Favorite Violin Encores
Artist: Margo Garrett | Jaime Laredo
Genre: Classical / Chamber Music
Label: Dorian
Release Date: 1993
A Treasury of Favorite Violin Encores- Meditation from Thais 16bits/44.1kHz AIFF檔串流試聽
今天給大家試聽的是小魚小時候最愛的小提琴專輯
這些曲子都是古典音樂之中非常優美動聽的小提琴小品 所以這張就稱為22首最受歡迎的小提琴安可曲
這張的錄音充份把史特拉瓦底名琴的優美音色發揮出來 好聽的音樂和優秀的錄音和演奏
用數位檔案的方式來播放 更能突顯出這張專輯的經典!
以前魚爸最喜歡放這張CD~ 耳濡目染下全部的曲子小魚都已經能背誦哼出來....
這裡的母帶音樂並非高解析的檔案
但是比我們從CD rip進來的 好聽的太多了... 手邊有CD的朋友請拿比較出來^^
這兩首曲子的資訊如下:
03. 馬斯奈:泰綺斯冥想曲
Meditation from Thais - Jules Massenet / Marsick
04. 德弗札克:幽默曲
Humoresque - Antonin Dvorak / Saenger
【2012/01/16 推薦專輯:Buena Vista Social Club】
Title:Buena Vista Social ClubBuena Vista Social Club- Chan Chan 24bits/96kHz AIFF檔串流試聽
Artist:Buena Vista Social Club
Genre:World
Label:Nonesuch
Release Date:1997
Buena Vista Social Club- Chan Chan 16bits/44.1kHz wav檔串流試聽
給大家試聽的是樂士浮生錄中的Chan Chan
熱情的古巴器樂搭上磁性的嗓音 唱出輕鬆又韻味十足的旅程....
從奧托山多 我要前往馬卡尼
經過奎多,再往瑪亞尼....
【2012/01/15 推薦專輯:Entre Cada Palabra】
Title:Entre Cada Palabra
Artist:Marta Gomez
Genre:Latin / Colombian
Label:Chesky Records
Release Date:2006
Marta Gomez- Cielito Lindo 24bits/96kHz AIFF檔 點擊串流試聽
Marta Gomez- Cielito Lindo 16bits/44.1kHz wav檔 點擊串流試聽
串流給大家試聽的是 墨西哥民謠 Cielito Lindo "美麗的天空"
周末就應該聽這種歌~撫慰人心....
此篇文章於 2012-02-27 08:10 PM 被 小余 編輯。
YES!搶頭香~~~~~~~~~~~~~
