第6頁,共12頁 第一第一 ... 45678 ... 最後最後
顯示結果從 51 到 60 共計 119 條
  1. #51
    我用的是Windows 7 64-bit,比較後我喜歡接Firewire的聲音就一直用Firewire,不過USB還是一樣會插著,沒經過HUB,線材是Oyaide d+ 1394/class s USB
  2. The Following User Says Thank You to L.E.D For This Useful Post:
  3. #52
    引用 作者: L.E.D 查看文章
    感謝,網兄有試過別的1394線嗎?
  4. #53
    引用 作者: hkimo 查看文章
    Pre-amp Version的Analog in是直接訊號輸出嗎??
    若是打開Up samplig,請問訊號會通過Chip嗎?
  5. #54
    Firewire Recording
    這會是個好玩的功能
    試想從esoteric和mytek共用clock,然後從esoteric數位輸出拉訊號進入mytek,再從firewire錄進電腦,這種rip方式應該很有遐想空間....:^)
  6. The Following User Says Thank You to john925 For This Useful Post:
  7. #55
    with 176.4 and 192 both lit, DSD can play through CAS.
  8. The Following 2 Users Say Thank You to john925 For This Useful Post:
  9. #56
    "with 176.4 and 192 both lit, DSD can play through CAS."
    麻烦你解释一下什么东西用176.4和192?CAS?
    我对MyTek DSD192 很感兴趣。I have ripped all my SACD into dsd via a PS3.
    PowerConditioning: PS Audio UPC-200
    SC: Asus Xonar STX, Juli@
    Source: Audio-GD NFB9, Mytek DSD 192, Zhaolu DAC 2
    Amp: Audiolab 8000 C/P; Melody SP3; Audio-GD C501
    Speakers: Spendor SP2, Stirling LS3/5a
    Headphone: Sennheiser HD650
    Software: ContolPC (Windows 20AJRiJ- AudioPC (Windows 2012)
  10. #57
    meitner ma-1剛推出的時候,是不能支援dsd的播放,所以在面板上沒有dsd的指示燈,經過軔體更新後才能夠支援電腦播放dsd,而廠方所用的方式就是同時亮176.4和192兩個指示燈,來顯示meitner有接受到來自CAS(Computer As Source) 的dsd訊號
    mytek要播放dsd也是可以,不過請用1394。meitner的usb軔體寫得比較好....
    引用 作者: mtan002 查看文章
  11. The Following 3 Users Say Thank You to john925 For This Useful Post:
  12. #58
    我没用过firewire. 一向用RCA or optical SPDIF. 要用firewire也不是个问题。
    你是用 PC or Mac? 哪一个player software? 有比较过SACD and dsd native 的声音吗?
    Why did you choose Meitner over Mytek?
  13. #59
    引用 作者: mtan002 查看文章
    I use a Mac Mini Server with Windows 7, player is J.River.
    I do think SACD player, I have Esoteric UX3-pi, and DSD DAC will show more differences than similarities, because they are too different. Just see which way you prefer, a physical touch to take a SACD disc out of a case elegantly or a swipe on the ipod to make the music rock.
    Meitner and Mytek are different in price, function, and sound character, etc. I use them in different systems.
  14. #60
    引用 作者: L.E.D 查看文章
    韌體版本1.4.2以上才支援遙控,升版後按照說明書把機子的遙控功能打開
    去買市面上隨便一支萬用遙控器,自己順眼就好,不過建議買數字鍵大一點的,會比較好按
    然後找Philips的控制碼,一個一個試,總有一個是可以用的,之後就照說明書遙控就好
    請教L.E.D兄,不知道你mytek上設定的遙控功能是設在1. tv mode 2.preamp1 mode 還是 3.cd player mode...感謝!
    設定之後,除了大小聲可以調整以外,power on/off有作用嗎?
    看ComputerAudiophile的討論區,據說遙控碼是0211...有興趣遙控的可以試試看
    thanks a lot
