第4頁,共5頁 第一第一 ... 2345 最後最後
顯示結果從 31 到 40 共計 45 條
  1. #31
    Amarra 2.3是最新版本我感覺它是由電腦播放音樂中聲音質素最高的方法。由專業工程師背景如Michael Romanowski, Paul Stubblebine, Terra Nova, Michael Fuller, Charlie Pilzer, George Massenburg, Gavin Lurssen, Dave Glasser, Reference Recording Keith O. Johnson還有一大班母帶製版師全是Sonic Amarra用家。這說明大家喜愛的音響”天碟”,在出生之前,已經由Amarra(Sonic)參與其中。2011年10月剛剛完成的Rocky Mountain Audio Fest (RMAF)有超過20間房間使用Amarra作為重播軟體。當中包括大家熟識的dCS, Ayre, Musical Fidelity, Focal, D’Agostino。當時TAS寫手Steven Stone認為Amarra 2.3是有史以來最佳版本,選為 Most Significant Product Introduction “Judging by the number of rooms using it and the quality of their sound, Amarra’s new 2.3 build is a major step forward in ergonomic flexibility, platform stability, and overall sonics.”2011年11月美國Stereophile推選Amarra 2.3為電腦播放年度大獎 – Computer
    Audio Component Of The Year。
    http://designwsound.com/dwsblog/2011...-專業背景/
  2. #32
    JPLAY 的V4版已經更新
    除了和FOOBAR結合後更好用外
    音質也有提升
    目前是感受到與V3版的低音更加扎實及深度
    其他....找時間在聽聽看(最近比較忙)
    休眠模式還會停格在播放前的畫面~讓使用者可以欣賞封面(要自己播放專輯封面)
    不過不太穩定就是了....有時候休眠依舊會像V3版全黑給你看
    此篇文章於 2011-12-08 11:52 PM 被 v121227706 編輯。
  3. The Following User Says Thank You to v121227706 For This Useful Post:
  4. #33
    有條件的免費版Amara
    只要是M2tech,Musical Fidelity,Weiss,Sonic Studio以上4家的dac產品用戶
    都能免費得到一份使用amarra核心(只支援到24/96),但只有撥放功能的免費軟體
    明年似乎還會有其他家(Coming in Early 2012 : Bel Canto, Wadia, PeachTree, and ...)也能得到這份禮物
    參考連結
    http://www.sonicstudio.com/amarra/amarra_dac.html
    http://designwsound.com/dwsblog/2011...ifi-for-weiss/
  5. The Following 3 Users Say Thank You to sniper0710 For This Useful Post:
  6. #34
    release of MusiCHI Suite Ver 3.0
    Among the new features, for the audiophiles in particular
    We added WASAPI Support, which is the native MS Windows way to by-pass the mixer and achieve bit perfect output this way, before we had only ASIO
    We can call the ASIO configuration panel inside the player
    For those who do not like Flac, because they think uncompressed audio sounds better we added WAV and AIFF support, that can be tagged, compatible with the custom fields of DBPowerAmp.
    We added Volume control and a mute which at 100% is still bit-perfect
    And many more features....
    I attached a press release in case and a new screen shot of the player
    www.musichi.eu
    MusiCHI Suite©® Version 3.0
    A New Milestone Version of the Music Software Suite
    dedicated to classical, jazz or other more demanding genre of music now available
    MusiCHI Suite, the first application completely dedicated to classical, jazz or other more demanding genre of music, has recently launched a new more powerful release. MusiCHI Suite Version 3.0 is equipped with many new features, many of them addressing the audiophilesaudience, which has embraced the program from the very beginning.
    MusiCHI Suite now supports WASAPI (Windows Audio Session API), allowing to by-pass the video sound mixer of Windows and achieving bit perfect digital output. Furthermore, the support of WAV & AIFF files has been added, which can be tagged with the powerful tools provided within the software, also compatible with dBpoweramp custom fields. Worth reminding that the Suite is ASIO Drivers compatible, including ASIO4ALL, having passed bit transparency tests with a Weiss DAC202 and can play FLAC files up to 24 bits/192 KHZ, with additional support for MP3, MP4, WMA and M4A.
    These features create an even more “audiophile friendly” environment to be appreciated by everyone that adores perfect sound.
    Furthermore, a volume control & mute is now available*, together with a configurable playing queue to show the fields you want displayed both classical and other styles.
    MusiCHI Suite V3.0 also offers the possibility to add or refresh music folders directly from the player in addition to doing the same task from the Library Manager. In the new version’s Tagger you can, also, rename audio files with a combination of track Number and the metadata “Name, title or movement”.
    Finally, more composers and performers have been added to the Suite’s reference database for classical music, MusiCHI Clean©®, where more than 6000 entries (composers, performers, orchestras, etc.) have been properly corrected and normalized with full respect of their local spelling (umlaut, accents etc.),i.e. the program is fully Unicode compliant. In the MusiCHI Suite V3.0, the works of Haydn and Shubert have been added to the already existing integrated catalogs of the compositions of other composers such as Mozart, Beethoven, Bach, Vivaldi, Handel, Chopin, Mahler and Brahms.
    MusiCHI Suite can be downloaded through the website address: www.musichi.eu.
  7. #35
    有沒師兄能討論一下 Windows 上的Player嗎?
    小弟用的foobar2000已經很好聲
  8. #36
    同上,我也在用 foobar2000
  9. #37
    在用JRMC 17
    國外討論的TOPIC
    http://www.whatsbestforum.com/forumd...-Music-Servers
  10. #38
    想請教一下mac有沒有哪一套播放軟體
    能夠連到internet 上的upnp server?
    嘗試了vlc跟xbmc似乎都只能夠連結到LAN下面的.....
  11. #39
    RMAF 2012: Channel D Updates Pure Vinyl High Resolution 192 / 24 Analog to Digital Transfer and Pure Music Digital Music Player Software
    Channel D will be demonstrating major new updates to their award winning Pure Vinyl software for making high resolution digital transfers of analog sources and Pure Music digital music player software at the 2012 Rocky Mountain Audio Fest, October 12-14, in Exhibit Room 482.
    - Pure Vinyl 3.1 represents a significant update including performance and usability enhancements including new easy to use Jog and Insert Track controls for editing and splitting LP recordings into individual tracks. Pure Vinyl 3.1 will be released on October 23, 2012.
    - Pure Music 1.9 includes over two dozen performance enhancements and new features. Pure Music 1.9 will be released on October 30, 2012.
    Both updates will be free for all users.
  12. #40
    請教各位網兄:
    想添購一台筆記型電腦來撥放數位音樂,不知要選擇mac還是windows系統較合適?當然撥放軟體音質與方便性也相當重要?麻煩眾網兄們來幫忙解惑.....感謝
