第3頁,共5頁 第一第一 12345 最後最後
顯示結果從 21 到 30 共計 45 條
    WIN 的等小葉板主吧~我幾乎不用 暈倒死 了 ....
    虛空有時盡 我願仍無窮
  2. #22
    Jplay V3.4 今天release
    早上已經收到Jplay那邊寄過來的檔案了
    比較吸引人的幾點
    Throttle mode :
    You asked us to bring ‘normal’ playback closer to Hibernate mode
    and we listened!
    終於可以一邊上網一邊又有比D mode更好的音質了~
    Playback order:
    Repeat’ will keep playing same playlist forever –
    thanks to our friends from Taiwan who requested this!
    另外右上角的X關掉程式可以靠參數取消掉也很讚,之前偶爾會手殘按掉
    新增的參數還有取消會自動把playlist sort的問題
    其他部分就請各位看官方的說明吧 :)
    http://jplay.eu/computer-audio/jplay-v3.4/
  3. #23
    請問目前聽起來的話哪套軟體音質是最好的呢?
    BUY NICE. OR BUY TWICE.
  4. #24
    Audirvana moves to Plus beta w/ iTunes integration
    Posted: November 9, 2011 | Author: John Darko | Filed under: Software | Tags: audirvana | Leave a comment » Audirvana development keeps on keeping on. It’s definitely one of the better audiophile-quality music players for OS X but the new beta (“Plus”) version pulls an even bigger rabbit from the hat – iTunes integration. Wow.
    “Audirvana Plus can now, in addition to its independent playlist mode, be fully controlled by iTunes.
    In this mode, Audirvana Plus works transparently in the background, replacing the audio engine, while iTunes is used as the library to select, control the tracks to play.”
    The killer blow? “This also enables to use the Remote app for iPhone & iPad”.
    Sonic Studio (Amarra) and Channel D (Pure Music) should be afraid, very afraid.
    You can grab this new beta of Audirvana right here (from their newer, slicker website) but the full version of Audirvana Plus will (eventually) run you US$49.
  6. #25
    能整合在大家長iTunes下背景運作 真棒!
  7. #26
    BitPerfect真是不错,我已经删掉之前破解版Amarra2.3了。
  8. #27
    我是正版amarra mini2.3,刚买的,与bitperfect做了仔细比较,觉得还是amarra好过很多。
    我听过破解版的2.2,感觉不是真正的内存播放,声音干硬,不知道您的破解版amarra2.3是否也是假内存播放。
  9. #28
    比较一下,Fidelia还是不错的,而且设置需要仔细推敲一下。
  10. #29
    AudioGate 注册真是麻烦,而且没有成功,所以放弃。
  11. #30
    24bits/192kHz的 AirPlay軟體推出了~ 250歐 與iTunes完美結合
    Rosita Plugin 相關說明
