第7頁,共9頁 第一第一 ... 56789 最後最後
顯示結果從 61 到 70 共計 82 條
  1. #61
    引用 作者: wu 查看文章
    請問i5 16g,w7 64bit,jplay+iTunes上網有時會頓能否改善,謝謝
    這個一定有問題,我只是I3還降頻,都可以同時跑 JPLAYMINI、ITUNES、GOLDWAVE、EAC、BT(噓....)....絕對不會頓的!
  3. #62
    跟試用版有關嗎,老婆說會頓不准買
  4. #63
    引用 作者: wu 查看文章
    跟試用版有關嗎,老婆說會頓不准買
    喔....試用版原本就是會頓,逼使用者非買正式版不可啊!........
    wu
  6. #64
    我以為只會無聲,只好找余老闆
  7. The Following User Says Thank You to wu For This Useful Post:
  8. #65
    哈哈哈 我只是幫忙代購啦.... 我自己用AirPlay用得很開心 XD
  9. #66
    JPLAY v4.3A!
    Maintenance release containing fixes for known issues in 4.3:
    - hibernate.settings did not work unless settings were updated
    - JRiver plugin was cleaning Playing Now playlist: now it will do so only in Hibernate mode
    - In some cases (e.g. loading tracks from NAS taking too long) plugins could lose sync with jplay service and 'freeze' requiring manual restart
    - On some machines (mainly quad-core) ALAC decoding was not working properly
    - On some machines gapless could cause a small tick when loading FLAC & ALAC tracks
    - Various small code fixes
  10. #67
    我在听他的试用版本,我用win7 64bit的,要想请小余购买两套。
  11. #68
    引用 作者: 小余 查看文章
  12. The Following User Says Thank You to baoshengshi For This Useful Post:
  13. #69
    引用 作者: baoshengshi 查看文章
    請來這邊回覆~並訊息給我一下! 謝謝!
    【JPLAY 代購】長期優惠代購,請跟小余聯絡
    http://www.my-hiend.com/vbb/showthread.php?6012
  14. #70
    今天才看到
