可能價位高 競爭對手也多
Post from tapatalk app
Dynaudio XEO2 生產照片
Have you ever wondered where we make our Xeo 2 loudspeakers? We grabbed our camera and walked just across the road over to our factory and met two of our valuable colleagues: Lene and Gitte
They have been at Dynaudio for eleven and five years respectively, and now they are assembling our latest loudspeakers, the Xeo 2. According to Lene, the Xeo 2 is actually one of the most fun loudspeakers to work on – but she might be biased as she has a pair at home. But which one was the most fun? “Without a doubt the Evidence,” Lene says.
印象中阿比特以前臺灣展覽有出現過
Dynaudio官方臉書再出現這套不尋常,很可疑喔
難道...Dynaudio要再推出擴大機嗎?
Did you know it took a speaker manufacturer to produce the best amplifier in the world?
Originally, we developed the Arbiter for internal use only; however, the interest was overwhelming for this magnificent amplifier, and because of this, we decided to produce a limited batch of 50 complete sets.
The Arbiter was, and still is, unlike anything else on the market. With its battery-powered design, over 1.000-watt output power, a bandwidth from nearly DC to 300 kHz, and probably the most elaborate volume control ever created, the Arbiter still ranks among the very best even 20 years after its birth.
Have you ever heard the Arbiter in action?
一個悠閒的午後 一台筆電 一對質感音質兼俱的優異揚聲器 再配上一杯剛煮好的現磨咖啡 享受人生 如此簡單而已
The Following User Says Thank You to Evan For This Useful Post:
限量冰藍,Dynaudio 推出 Xeo 2 Limited Edition Ice Blue 無線喇叭
http://www.review33.com/news/news.ph...20160616215751
來自丹麥的 Dynaudio 成立於1977年,可說是世界首屈一指的喇叭生產商,由單體及成品喇叭均有製造,向來以工藝精湛馳名。Dynaudio 自 1980 年代起發展出不少優秀的系列,廠方執著追求真實自然的完美的音樂還原性。而近年廠方積極研發具無線接收的有源喇叭 XEO 系列 ,這次他們宣布,即將推出 Xeo 2 Limited Edition Ice Blue 紀念版本,全球限量 500 套。
Xeo 2 Limited Edition Ice Blue 承襲了 XEO 2 的二路書架喇叭結構,整體音箱採用鋁合金製作,並增加了和 Focus XD 系列相同的數位輸入功能,而 Xeo 2 Limited Edition Ice Blue 採用了全新冰藍面板加純白色機身的造型,較普通版外型更時尚醒目。
Xeo 2 Limited Edition Ice Blue 頻率響應達 40Hz 至 24kHz 的高平,高音與中低音各以一部 65W 放大器驅動,內部搭備DSP數位主動分音,以及特有的 Adaptive Bass Technology 低頻自適應技術,可讓擴大機在不同負載下的低頻達到最佳化,因此低頻延伸卻能輕鬆達到 40Hz 。此外,全機均採用鋁合金製作,音箱的剛性極高,且更有利於降低音箱諧振,減少內部音染。
除了原有的無線接收外,Xeo 2 Limited Edition Ice Blue 同樣具備 XEO 2 所新增了藍牙輸入功能。搭配自家的 XEO Hub 或 XEO Connect 傳輸器後,可同時控制多組喇叭,若不以傳輸器作連接,用戶亦可透過藍牙方式進行無線播放。此外亦設有數位輸入功能,透過光纖輸入,最高可支援至 192kHz 。除此之外,亦提供 RCA 與 3.5mm 類比輸入各一組。機身設有 3 段喇叭擺位調整功能,讓用家可針對一般視聽狀況、牆角擺放,或是靠近背牆擺放而自行切換,讓用戶在擺位上更具彈性。
Dynaudio 最近由中資背景的 GoerTek Inc 入股成為大股東,各地粉絲均密切關注廠方的生產方針及產品研發,這次該廠推出 Xeo 2 Limited Edition Ice Blue 限量版本喇叭,造工及質量均保持一貫高水準,相信能一掃愛好者心中的疑慮。
詳細規格:
Power Output:130 Watt
Tweeter:27 mm
Woofer:14 cm MSP
Frequency Response:40Hz-24kHz
Bluetooth:Yes
Connections:3.5mm stereo mini-jack, RCA, Optical
Dimensions (HxWxD):255 x 173 x 154
Weight:4 kg
Warranty:60 Months
Package Contents:Remote Control, 2x Power cable 2.5m, RCA cable 1.5m, Optical cable 1.5m, Mini-jack stereo cable 1.5m, QuickGuide
資料來源:https://www.wifimedia.eu/en/dynaudio...-ice-blue.html
Dynaudio Xeo 2 inside
