第2頁,共8頁 第一第一 1234 ... 最後最後
顯示結果從 11 到 20 共計 73 條
    我也來報到
    CRM 2.3 FE
    沒有鑽石高音只是次一級的鈦高音
  2. The Following 2 Users Say Thank You to jeremywang For This Useful Post:
  3. #12
    oh...my god.....器材這勒壯觀.............
  4. #13
    一直對Kharma的喇叭很有興趣, 但是.....真是貴啊!!只能望叭興嘆阿...
    話說一直很喜歡Kharma的喇叭, 所以有時也會去逛一下官方網站, 目前發現他們好像推出新產品了.....
    原本CRM系列的似乎都不見了, 取而代之的是"Elegance"系列, 但是價錢我想也是不便宜吧!!應該是會更高價的.....KHARMA的路, 越來越遙遠了~~
    貼幾張照片看看吧~~不知道台灣代理何時會引進呢?真想一聽"Elegance"的風采~
    Elegance DB9
    Elegance DB7
  5. #14
    引用 作者: ewewe 查看文章
    Elegance DB9
    Elegance DB7
    高音好像改成BE高音
    中音單體近看 材質跟Morel的新產品很像
  6. #15
    引用 作者: ewewe 查看文章
    台灣預計3月份第一週到貨,歡迎大家來試聽喔~ :)
  7. #16
  8. #17
    老大記得拍開箱喔...............
    沒意外的話會拍的
  9. #18
    預設 Kharma Exquisite Midi
    Signature €80000
    The new Kharma Exquisite Midi is designed and built without compromise. Every part of this speaker, from the extreme dense HPL-plates to the smallest details has a function in the complex process of creating ultra high-end sound. The advanced Diamond dome technology used in the Exquisite Collection emphasizes this incredible attention to detail even more. Furthermore the uncompromised design also resulted in the beauty of the Exquisite Midi, which is for example shown by the gold-plated sidetrimming or the new high-gloss Macassar panels.
    Stand
    Mechanical residual vibrations of the cabinet are terminated by the Spike Disk Suspension System (SDSS) by minimising the contact area between the cabinet and the floor. The SDSS stand also provides a fixed and levelled orientation for the cabinet drivers, because each spike can be adjusted individually in the vertical direction.
    Drivers
    · High-frequency: 1 x 1-inch Diamond concave tweeter
    · Mid-frequency: 1 x 7-inch Black label driver
    · Low-frequency: 2 x 8-inch Nomex-Kevlar driver
    The musicality you may expect from the Exquisite Midi is for an important part created by the drivers, which can be seen as the engine of the loudspeaker. The quality of the driver is therefore crucial to compete with reality.
    Without a doubt the quality is guaranteed by using a Diamond tweeter as a standard in the Exquisite Collection. These high-frequency drivers are true technological wonders. The tweeters have a diamond cone which have been realised by the so called CVD process. With this process incredible stiffness is reached with a minimum of thickness of only 50 μm. Notice a human hair is in the range of 17 to 180 μm. The cone is the most essential part of the tweeter and because this cone is made of Diamond the tweeter is capable to create impressively pure high frequencies.
    Black Label driver
    The midrange driver, Kharma’s so called Black label driver, is an improved version of the long used Ceramique driver. These drivers are free from any cone-born resonances in the whole used frequency range and they have been optimized carefully by lasercutted patterns as to push up these resonances to frequencies beyond the used frequency range.
    Nomex-Kevlar driver
    The two woofers have 8 inch sandwich-honeycomb-Kevlar cones which also again are completely free from structure born resonances in the used frequency range.
    Technical specifications
    System: 4-way
    RMS power: 250 Watt
    Program power: 500 Watt
    Frequency range: 23 Hz – 90 kHz
    Nominal impedance: 4 Ohm
    Efficiency 2.83V/1m: 90 dB
    Maximum SPL: 113 dB
    Dimensions
    Although the Exquisite Midi is designed for a smaller space, it produces the same sound quality as the Exquisite Classique. For this reason the physical dimensions of the Exquisite Midi are more modest than those of the Exquisite Classique.
    Including stand
    Width: 390 mm / 15.35 inch
    Height: 1013 mm / 39.88 inch
    Depth: 647 mm / 25.47 inch
  10. #19
    預設 Kharma Exquisite MP1000
    €40000+
    The Exquisite MP1000 Series consist of different versions of the Exquisite Mono Power Amplifier:
    · The Exquisite MP1000 Reference
    · The Exquisite MP1000 Signature
    Exquisite Reference Mono Power Amplifier MP1000
    This version of the MP1000 Series is marking the reference in the MP1000 Series, where all features have to be heard to be believed and are summarized as follows:
    · Double transformer
    · Unique Class A / AB Kharma proprietary circuitry
    · Ultra High grade power supply
    · Elaborate protection + software controlled soft start
    Besides, this model has standard a beautiful frontpanel with Kharma trapeziums and a black anodized aluminium cabinet.
    Exquisite Signature Mono Power Amplifier MP1000
    The Signature MP1000 Amplifier is a special version of the MP1000 Reference, where both technical as visual the Mono Power Amplifier is upgraded.
    The MP1000 Signature amplifier does not only have all the nice features the MP1000 Reference has, but also has additional very special features:
    · Double Silver transformer
    · Mono-Atomic Silver internal wiring
    · Diamond-Tunqsten SDSS-stand
    · Luxury frontpanel design
    Besides, there is the option to execute the MP1000 Signature in blank anodized aluminium instead of black anodized aluminium. Moreover some different frontpanels will be available, where the MP1000 Signature standard already has a very special wood-inlay Kharma design frontpanel.
    Kharma Privileges Program
    As for all products from the Exquisite Collection there is the possibility to enter the Privileges Program for the amplifiers of the MP1000 Series.
    A glimpse of what is possible
    Features
    The Exquisite Mono Power Amplifiers from the MP1000 Series all have unique class A / AB Kharma proprietary circuitry. That the Exquisite MP1000 is designed with an incredible attention to detail, is amongst others stressed by the ultra high grade power supply, double transformers and silver/gold internal wiring. The internal wiring of this power amplifier, which has the same high quality as used in the entire Exquisite Collection, combined with external cabling to the Exquisite loudspeakers results for this reason in a sonic match throughout the whole ultra high-end audio set.
    The Exquisite MP1000 is equipped with double special audio transformers designed by Kharma to purify the sound of this amplifier. Moreover the amplifier has a copper case attached to the solid body. The copper case leads to shielding against residual radiation that can originate from the end of the external power cable. As a result the interference between the external power cable and the amplifier is minimized. Hence the amplifiers in the MP1000 Series are equipped with an elaborated protection. Besides the amplifiers have a software controlled soft start.
    System: Mono Power amplifier
    Power: 390 Watt at 8 Ohm
    756 Watt at 4 Ohm
    Peak power: 2700 Watt at 3 Ohm
    Peak current: 30 Amps
    Frequency range: 1 Hz – 200 kHz
    Total Harmonic Distortion (THD): < 0.001
    Inter-Modulation Distortion (IMD): < 0.001
    SNR: < -112 dB
    Input impedance: 10k Ohm
    Dimensions
    Including stand
    Width: 450 mm / 17.72 inch
    Height: 225 mm / 8.86 inch
    Depth: 678 mm / 26.69 inch
  11. #20
    預設 Kharma Exquisite P1000
    €30000+
    The Exquisite P1000 Series consist of different versions of the Exquisite Preamplifier:
    · The Exquisite P1000 Reference
    · The Exquisite P1000 Signature
    Moreover there is also the possibility, as for all products in the Exquisite Collection, to adjust the product totally to your style and wishes by entering the Privileges Program.
    Exquisite Reference Preamplifier P1000 This version of the P1000 Series is marking the reference in the P1000 Series, where all features have to be heard to be believed and are summarized as follows:
    · Fully Balanced
    · Silver transformers in the AC power supply
    · Hand wired / soldered point to point wiring in the audio circuitry
    · Sophisticated remote controlled motorized discrete stepped attenuator with the very best resistors
    Exquisite Signature Preamplifier P1000
    The Signature P1000 Preamplifier is a special version of the P1000 Reference, where both technical as visual the preamplifier is upgraded.
    The P1000 Signature amplifier does not only have all the nice features the P1000 Reference has, but also has additional very special features:
    · Mono Atomic Silver internal wiring
    Besides, there is the option to execute the P1000 Signature in blank anodized aluminium instead of black anodized aluminium. Moreover some different frontpanels will be available, where the P1000 Signature standard already has a very special wood-inlay Kharma design frontpanel.
    As for all products from the Exquisite Collection there is the possibility to enter the Privileges Program for the preamplifiers of the P1000 Series.
    Features
    The Exquisite preamp Series is equipped with hand wired discrete point to point wiring made of our finest solid core silver-gold alloy, which is treated with proprietary Kharma techniques. During auditions it was established that no circuit board is able to reveal the depth of the sound space the way discretely wired components do.
    The volume control of the Exquisite P1000 preamplifiers are also a zero compromise state of the art design with “naked” Z-foil resistors in a discretely switched shunt attenuator that is again fully wired with Kharma pure silver-gold wiring. Furthermore, the source control is of course also a completely discrete circuit, wired point to point, no circuit boards, just pure silver-gold Kharma wiring to ensure the elimination of any
    compromise in the signal path. As a result the audio circuit as a whole is extremely pure and on top of that, it is powered by an incredibly clean power supply that prohibits any outside interference affecting the signal path. This is illustrated by the properties of the power supply which has such a long RC-time that it takes about one hour to fill the capacitors to their maximum potential.
    The result has to be heard with extreme quality loudspeakers to fully unveil the inner quality of this preamp. For the volume setting to be remotely adjusted, we have designed a sophisticated two-way RF remote control unit. This allows real-time updates of the volume setting to the RC unit over a considerable distance, which enhances usability. Hence the sophisticated remote controls the motorized discrete stepped attenuator in an optimal way.
    System: Fully discrete solid state class-A preamplifier
    Power: 60 Watt maximum
    Input sensitivity: 2.4 V
    Gain: 18 dB
    Frequency range: 10 Hz – 200k Hz ±0.2 dB
    Total Harmonic Distortion (THD): < 0.004
    SNR: > 90 dB
    Input impedance: 50k Ohm
