瑞士 CH Precision D1 SACD/CD 唱盤
D1是SACD/CD Player,日幣3,200,000
D1 Reference grade stereo or multichannel CD/SACD unit
CH's D1 Reference grade CD/SACD unit examplifies state-of-the-art Swiss precision and
utmost dedication to faithful musical reproduction.
Built around the Esoteric VMK-5 VRDS CD/SACD pick-up mechanism, the D1 offers a fully
modular and evolutive architecture based on optional slot-in boards for its audio outputs.
Each audio output board supports two channels of audio output, either digital (DIGITAL_OUT
board) or analog (ANALOG_OUT board), allowing almost any configuration ranging from a
simple stereo analog only player to a multi-channel purely digital drive. Whereas the DSD
signal is down-converted to 16bits/44.1kHz (using in-house algorithms) for standard digital
outputs, the D1 also integrates the proprietary CH Link interface which not only supports
cyphered transmission of native DSD data but also phase compensated synchronization when the D1 is used with one
or more C1 digital to analog converter(s). Analog outputs are based on a differential dual mono converter topology
coupled to a fully discrete output stage. Both balanced and single-ended outputs are provided.
The user interface is based on an ergonomically designed dual concentric rotatory knob with push function and
feedback is given by a 24bits RGB color programmble high-definition AMOLED display. A custom infrared remote
control allows access to the D1's most common functions.
An oversized, multi-regulated linear power supply and meticulous attention to mechanical design, construction and
assembly ensure optimal operating conditions for all circuits, especially the clocking section which benefits from its own
dedicated power supply.
Extensive external synchronization capabilities can be added by the SYNC_IO optional slot-in board. This board
provides standard wordclock input and output on BNC connectors as well as a proprietary CH Link clocking interface
providing phase compensated synchronization when used with the future CH clock generator.
D1 Specifications
General:
Supported discs
Display
Power supply
Power consumption
Dimensions / Weight
Remote control
Digital outputs (DIGITAL_OUT board):
CH Link
AES-EBU
Coaxial (S/PDIF)
TosLink (S/PDIF)
Analog outputs (ANALOG_OUT board):
Outputs
Output level
Frequency response
Dynamic Range (DNR)
Signal to Noise Ratio (SNR)
Total Harmonic Distortion + Noise (THD+N)
Synchronization (SYNC_IO board):
CH Link
Wordclock input
Wordclock output
General:
SACD (stereo or multichannel), CD, CD-R/RW
480 x 272, 24bits color, AMOLED
Selectable 100V, 115V, 230V AC, 47-63Hz
< 1W (standby), 30W average (operation, stereo)
440mm x 440mm x 120mm (W x D x H) / 32kg
IR remote control, RC5 codes
HD link, PCM (up to 768kHz/32bits) / DSD (cyphered), sync.
XLR, 2.5Vpp, 110 Ohms, 16bits/44.1kHz
RCA, 0.5Vpp, 75 Ohms, 16bits/44.1kHz
Optical, 16bits/44.1kHz
Balanced (XLR) and Single-Ended (RCA) connections
2Vrms (Balanced and Single-Ended)
DC-50kHz (SACD), DC-20kHz (CD)
120dB (SACD), 96dB (CD)
121dB (SACD and CD)
0.0015% (SACD), 0.002% (CD)
Proprietary clock link with phase compensation
BNC, 0.5Vpp to 5Vpp, 75 Ohms or Hi-Z, 44.1kHz
BNC, 2Vpp, 75 Ohms, 44.1kHz
www.ch-precision.com
日幣現在的匯率......這台真是有夠貴的........
CH PRECISION 「C1」DAC登場。
\2,500,000
CH PRECISION 「D1」登場。
\3,200,000
音響價格真不可親!一般大眾賺錢的速度都趕不上音響漲價的速度!........
小葉兄,
您好, 現有一問題想聽聽兄的意見.
小弟現想更換 SACD 機, 目標為單體式的, 想從 Eso K-01, Playback Designs, Emm Lab 及 CH 中挑選一部, 現用 SACD 機為 Lindemann D680.
小弟日常以聽 Classic 為主, 其次為 Jazz, 弦樂及人聲. 要求音色要自然及平衡度高.
有勞, 非常感激.
除了CH尚未有機會聆聽外 (臺灣似乎也沒代理,若兄在臺灣可能就不用考慮了)
這幾台都已建立在一個非常良好的基礎上(音色要自然及平衡度高都不是問題了)
重點在於這幾台的聲音特色相當明顯,只有聲音喜好的問題
K-01 未聽過,只聽過K-03,形體明顯與清楚,若能加上Clock如虎添翼,K-01在類比的味道上應該會更上層
PlayBack,流暢音樂性佳,不失細節
EmmLab,勻稱、有獨特的一種迷人韻味
答案希望您能自己前往聽聽看,再等您的分享!
多謝回复。
小弟也曾到各代理聽過 Playback, Emm Lab 及 K-01, CH 就未曾聽過。 耐何沒有一家店能有两台機同時出現, 更不用說4台了。 店家所用的前後級, 音箱及線材都完全不同, 挑選上真的有點難度。
The Following 4 Users Say Thank You to c7c For This Useful Post:
