USD 3,295
HDCD-compatible player with Philips VAM 1250 transport
24-bit Texas Instrument PM 1792 DAC with 192kHz sampling rate
The analog output stage uses a Chinese 12AX7 and two Russian 6922 dual triodes as well as WIMA and Solen capacitors and outputs to both RCA and XLR. There are also optical and coaxial digital outputs.
Technical Specifications
D/A converter: 24 bit / 192 kHz
Frequency response: 20 Hz - 20 kHz
Total Harmonic Distortion: < 0.003 %
Signal to Noise Ratio: > 90 dB
Dynamic Range: > 100 dB
Output impedance: 600 Ohm
Audio Output Voltage: 2.5 V
Channel Separation: > 90 dB
Tubes : 2x 6922 (= 6DJ8)
Inputs: 1x 3.5mm Jack (Power Control)
Outputs: 1x stereo XLR, 1x stereo RCA, 1x digital Coaxial,
1x digital Optical, 1x 3.5mm Jack (Power Control)
AC power connection type: 220V – 240V / 50 Hz
Dimensions (WxHxD): 430 x 135 x 368 mm
Weight: 10.8 kg
Colour: black/silver
www.vincent-tac.de
