顯示結果從 1 到 2 共計 2 條
    預設 Marantz PM8004、PM5004、SA8004、CD5004
    Marantz PM8004
    # 100W/ch (4 ohms), 70W(8 ohms) RMS Power (20Hz-20kHz)
    # “Current Feedback” topology for power amp and volume amp
    # marantz HDAM®-SA3 circuit
    # Shortest signal path, High Instantaneous Peak Current design
    # New Tri Tone Control (Bass/Mid/Treble)
    # “Constant Current Feedback” circuit for MM Phono Equalizer
    # Marantz Custom Speaker Terminals
    # Speaker A/B switching
    # Double shielded Toroidal Power Transformer
    # Triple Layered chassis
    # 3 analog L/R Inputs, 2 recorder In/Out
    # Power Amp Direct In for a use as a power amplifier
    # Pre Out jacks
    # marantz D-Bus(RC-5) Remote In/Out
    # Source Direct mode
    # Detachable Power Cord (IEC320 2pin type)
    # Auto Power Off function
    Marantz PM5004
    # Sophisticated Aluminum/Glass-reinforced resin hybrid front panel
    # Discrete-component amplifier with current feedback Pre&Power amplifier
    # Input buffer circuit for High S/N & Ch. Separation
    # Source Direct Mode
    # Fully discrete, MM phono stage
    # Active Filter type Tone Control, Loudness
    # 5 line-level inputs, 2 Record outputs
    # Transparent screw-type A/B speaker terminals
    # Triple command code sets
    # IR flasher input
    # IEC320(2pin) type AC inlet, Detachable power cord
    # 2 switched / 1 unswitched AC outlets
    # System remote controller
    Marantz America announced two integrated amplifiers, the PM8004 ($999), which replaces the PM8003, and the PM5004, ($449), replacing the PM5003. The PM8004 will be available in August 2010, and the PM5004 will be available in July.
    The new Marantz components continue the sleek symmetrical design featured throughout the company's product line, featuring the classic Marantz star mark, rock-solid construction and a unified cosmetic designed to complement the finest audio/video systems.
    Marantz' new PM8004 and PM5004 Integrated Amplifiers both derive their distinctive styling from Marantz' critically-acclaimed Reference Series models and feature a host of advanced audio-enhancing technologies, plus custom-installation friendly features such as three sets of IR codes, Flasher Input and more. The PM8004 features double-shielded toroidal transformers with full discrete constant current feedback and precision Marantz sound tuning. Additional industry-leading features in the PM8004 include HDAM-SA3 technology, on board high-current supply capability, Tri Tone Control, as well as Phono EQ (MM, Marantz Custom Speaker Terminals), and full discrete Current Feed back amplifier circuit.
    Marantz SA8004
    # Plays SA-CD (Stereo), CD, CD-R/RW(MP3/WMA/CD-DA)
    # Front USB (type A) input for USB memory & iPod/iPhone Digital Connection
    # Rear USB (type B) input for PC - up to 96kHz/24-bit
    # Digital Inputs (Coax/Optical) for DAC mode - up to 192kHz/24-bit
    # Digital Outputs (Coax/Optical) for CD/iPod/iPhone (SPDIF format)
    # Double shileded Toroidal Power Transformer
    # Double Layered Bottom Chassis
    # Exclusively designed Xyron Loader for pure audio playback
    # Discrete Analog Audio Circuit featuring marantz HDAM®-SA2 circuit with double side shielded printing board
    # Cirrus Logic CS4398 D/A Converter with Digital Filter
    # Dual PLL circuits for Low Jitter Signal Transmission
    # Zero impedance plate for a perfect equal GND potential between L/R
    # Audiophile Grade Custom Parts featuring ELNA capacitors
    # High Quality Headphone circuit by Current Buffer Output Amp.
    # L/R independent, gold plated high grade brass terminals
    # marantz D-Bus(RC-5) Remote In/Out Terminals
    # Display Off
    # Digital Out On/Off
    Marantz CD5004
    # IR flasher input
    Marantz America announced two new leading-edge audio players, the SA8004 SACD Player ($999), which replaces the SA8003, and the CD5004 CD Player ($349), replacing the CD5003. The SA8004 will be available in August 2010, the CD5004 and will be available in July.
    Marantz was one of the first manufacturers to debut a Super Audio CD player, and the company's new SA8004 continues its leadership posture in the category. Featuring HDAM SA2 processing, the SA8004 is an ultimate quality audio disc player that features a super-precise new drive mechanism, with three rear panel digital inputs (COAX, OPTICAL, USB), as well as a front-panel USB. The USB inputs can act as a D/A Converter for connectivity with iPod® Digital and other digital sources such as a PC or laptop. Users enjoy local control of Apple iPod and iPhone™, with SPDIF output of iPod music files and MP3/WMA playback.
    The new Marantz CD5004 CD Player features a Super Audio CD Grade 192kHz/24-bit Cirrus Logic CS4392 D/A converter, HDAM SA2 processing and more to provide superior playback of CD and CD-R/RW, MP3 and WMA files.
    "As an increasing number of people use their PCs, laptops, or other digital sources as transport vehicles for listening to their favorite music, they are also accepting compromises in overall audio performance. With internal upconversion technologies to improve the sound of today's high-resolution audio formats found in our new audio components, we are proving that the audio quality and power of digital music does not need to suffer. Even in today's MP3 music environment, our customers want the best sounding and most impactful home audio systems whether they are listening to a digital file or redbook CD."
    -- Noted Kevin Zarow, Vice President, Sales and Marketing, Marantz America
    http://us.marantz.com
