Accoustic Arts Player ES
Euro 2,990,2010年6月左右上市,有USB介面, 有升頻24Bit/192kHz
This device is not only an excellent designed CD player, but also a usable external D/A converter.
The D/A converter has a coaxial S/PDIF inputs and a USB input on for example a computer or other digital source can be connected.
upsampling 24-bit and 192 kHz.
www.accusticarts.de
PLAYER ES highlights
Premium CD player and high quality D/A converter in one unit
High precision 24 bit/192 kHz upsampling technology
High end tray loading CD drive mechanism (vibration de-coupled), which has exclusively been designed for audio applications
Damped, high quality drawer made of aluminium-ABS-compound guided with two metal bearings
Separate D/A conversion function with 2 digital inputs: 1 x coaxial (RCA) and 1 x USB 2.0
Easy playback of different audio formats (WAV, FLAC, MP3 etc.) from PC or laptop via USB interface ("Plug and Play")
4 separate, generously dimensioned power supply units for laser control, digital signal processing, display control and D/A converter section
Very high power supply capacity (more than 70,000 µF in total)
Spatial separation of analog and digital section within the D/A converter for best possible signal-to-noise ratio
Resonance minimising metal housing
Front panel made of finely brushed aluminium; tray cover made of massive and chromed brass
ACCUSTIC ARTS® system remote control SRC II
ACCUSTIC ARTS® PLAYER ES is "Handmade in Germany"
日幣価格¥609,000(税込)
http://www.accusticarts.de/pages/en_player-es.html
