第98頁,共158頁 第一第一 ... 488896979899100108148 ... 最後最後
顯示結果從 971 到 980 共計 1578 條
  1. #971
    The British company Rega, celebrating its 40 years of existence, is releasing a reference turntable, model Naiad. Available later this year, the model represents the culmination of philosophy turntables founder Roy Gandy. "This is a project without saving costs."
    To make the model even more special, early 40 Naiad turntables have sequential numbers, from 1973 to 2012, representing each year of the Rega and will also be signed by Mr. Gandy. The Naiad has a unique design, using the best of modern materials and manufacturing processes, with a base built by hand from carbon fiber to achieve maximum structural lightweight high stiffness, further strengthened with double wishbone ceramic.
    Mass is again reduced to a minimum, using a box bearing vertical titanium structure for mounting the turntable. The model will feature the world premiere in project "hub" bearing with a shaft and bearing housing made from zirconia.
    The model also has the best power supply Rega found in cases of reference of the company, offering adjustable speed control by user with a digital display.
    All turntables will be provided with a piece of music called Naiad, one of the favorite piano pieces Roy Gandy, which will be recorded by Rega. This single press includes a test signal which will run alongside power supply to ensure optimum speed is reached.
    Finally, the company ensures that the Naiad will be the best performance in the Rega turntables, promising to deliver beyond expectations.
    The Turntable Rega Naiad will be priced at £ 30,000.00 In the European market.
  2. #972
  3. #973
  4. #974
  5. #975
  6. #976
    OMA Tourmaline SP10 Turntable
    The OMA Tourmaline SP10 Turntable System uses the integrated platter and motor unit of the legendary Technics SP10 professional broadcast turntable, bringing it to an unprecedented new level of performance (and appearance).
    OMA removes the platter and motor from the stock SP10 chassis, and attaches them directly to a slate plinth which weighs approximately 210 pounds. This plinth is in two parts, to allow ease of transport and setup. The non resonant nature of our Pennsylvania slate, combined with the great mass of the plinth, ensures dead silent operation, with a blackness between notes and passages which is hard to imagine.
    The OMA custom built case for the original motor control components, which are now housed away from the motor, platter and cartridge, features slate sides which also double as feet, insulating the motor boards from vibration. OMA can offer this new product complete, or you can provide an SP10 as a donor which gives a discount on the final price.
    http://oswaldsmillaudio.com/tourmaline
  7. #977
  8. #978
    This is my revised Dual 1019 (mid 60's). I polished the platter, replaced the old rubber slip mat with a new, custom made plexiglass and installed a Denon DL 102, which is a great cartridge if you want to enjoy your old mono records. The white MDF frame was made by a carpenter.
    http://www.flickr.com/photos/6710146...istereophonic/
  9. #979
  10. #980
    前幾個禮拜回台探親,順便在東京過境時去玩了幾天(等時差調好了,再寫篇雜記)。
    到達東京的第一晚,先去秋葉原報到
    Real Cable 當然是回台後去新天新地買的。 去Yodobashi Camera逛的時候(很可惜,忘了帶照像機),有一層是賣音響和其它家用娛樂用品。有很大一塊區域是賣唱盤和唱頭的。去東京前,就盤算著去秋葉原買個日本唱頭。目標是AT OC9 MK III。可是Yodobashi的價錢並沒有比美國的更便宜。正在失望之際,看到這個在特賣中
    特價48000日圓!換算一下,大概是500多美元。在美國,這顆要賣八百多呢!Benz-Micro ACE S系列,有高,中,和低輸出三種。可惜低輸出的賣完了(大家都是識貨的),只能選中輸出的。
    拍個近照
    PS:現在暫時還沒打算裝起來聽。我還在和我的Harman/Kardan奮鬥,在還沒玩通前,還是別拿新玩具作白老鼠。
    此篇文章於 2013-07-12 09:32 AM 被 kevintran 編輯。
  11. The Following 3 Users Say Thank You to kevintran For This Useful Post:
