第81頁,共158頁 第一第一 ... 3171798081828391131 ... 最後最後
顯示結果從 801 到 810 共計 1578 條
  1. #801
  2. #802
  3. #803
  4. #804
    What do you suppose the tracking force is on that rig?
    (Elvis at the Knickerbocker Hotel in Hollywood, on Saturday, August 18, 1956 by photographer Ed Braslaff.)
  5. #805
    Danon Han Hong DenAnalogue Fellowship
    攝於 5小時前,透過手機
    ,在 Kampong Seri Medan, Wilayah Persekutuan 附近
    The Miyajima Kansui cartridge installed on my SME 30/2 turntable. Sounds very natural and pleasant. Make you believe that the music flows correctly and at the right pace. Obviously the designer is all about making the music just RIGHT...enjoy
  6. #806
  7. #807
  8. #808
    MicroMagic Altair cartridge and arm
    All prices in CHF
    Three models:
    Normal - 19000
    Special - 21000 - Normal and Special - compliance 6
    Special - 23000 - user selected compliance from 6 to 12
    Output voltage: 0.42 mV at 1 kHz.
    Recommended load impedance:> 110 ohms.
    Tracking force: 1.8 - 2.5 g
    Weight: 12.5 g
    Other MicroMagic cartridges:
    Silver Spirit LE - 15000 - weight 27g
    Magic Diamond - 7500 - weight 15,5g
    Virus - 5000 - weight 14g
    21000
    Limited Edition, only 40 will be made.
    Cartridge weight range 5-75g.
    5-pin DIN connector.
    Altair phono cable - 1,25m - 5-pin DIN to rca or xlr - 3900.
  9. #809
    Schröder LT Tonearm
    $8900
    LT looks like a conventional pivoted type, it's actually a sophisticated linear-tracking 'arm whose patent-pending mechanism keeps the cartridge's stylus in perfect tangency.
    It does this by adjusting the tonearm's pivot, which moves free of the mounting base via an ingenious magnetic mechanism. The LT offers no adjustment for offset angle or anti-skating; both are unnecessary, given the design. VTA/SRA, azimuth and tracking-force adjustment remain.
    The LT's wooden armwand snakewood or grenadill are available, is treated to eliminate the effect of temperature and humidity, and the headshell is made of a proprietary material chosen for its stiffness, low mass and great internal damping. Internal wire is a high-purity copper type that's been cryogenically treated.
  11. #810
