第55頁,共158頁 第一第一 ... 545535455565765105155 ... 最後最後
顯示結果從 541 到 550 共計 1578 條
  1. #541
  3. #542
  4. #543
    Pro-Ject Signature turntable
    €9500
    • Mass-loaded subchassis design
    • Magnetically decoupled main platter
    • Resonance-optimised alloy
    • Inverted main bearing with ceramic ball
    • Flywheel belt drive
    • Motor control system with LCD display
    • Single-pivot tonearm
    • High gloss metal surface
    • Piano-lacquer chassis with magnetic decoupling
    Signature is a non-compromise highend turntable that celebrates “20-years of Pro-Ject Audio Systems”. A highly sophisticated concept combines the mass-loaded principle with subchassis. Magnetic feet decouple the chassis from surface, “Sorbothanepillows” and a magnetic-floating platter guarantees an absolute quiet running turntable. A “flywheel” belt drive system ensures vibration-free running. The new single-pivot tonearm is a genuine Pro-Ject design. With its wide range of adjustment possibilities and the choice of adequate counterweights, nearly all cartridges can be mounted.
    Speed 33,45 electronic speed change
    Actuation principle Flywheel belt drive
    Motor control system Precision generator with LCD display
    Platter 10,55 kg magnetically decoupled
    Main bearing cramic (ball/plate)
    Tonearm 12”; single-pivot, aluminium
    Effective arm length 304,8 mm
    Effective arm mass 19,5 g
    Cartridge mass 4 - 10g, several counterweights included
    RCA connectors gold plated
    Power supply 16Volt/xxx mA included
    Dimensions 570x 470 x 250mm (WxHxD)
    Weight 34,3 kg
  6. #544
    With his family’s precision engineering and machining background, Christoph began his own journey of finding the best sound by building his own analog equipment. In 1999, Rossner and Sohn released their first commercial turntable. The latest special custom-made turntable is called “The Mott” (The Mother of Turntable). The rotating platter itself weighs 232 kg, and the combined unit weighs over 325 kg. Two versions of "The Mott" are available, one with oil bearing and manual adjustment (48,000€), and the full version with automatic pneumatic adjustment and air bearing (135,000€) In 2008, Rossner and Sohn won the Image Hi Fi Award for the Si 1.2 tonearm.
    Christoph Rossner, together with one of their latest flagship turntables
  7. The Following 2 Users Say Thank You to accl626 For This Useful Post:
  8. #545
    這個人很特別.......每次慕尼黑都有聊到......
  9. #546
    BBC 6 Music to play only vinyl on New Year's Day
    26 Dec 2011
    Here's a good bit of news for turntable enthusiasts: BBC Radio 6 Music has announced it will be playing only vinyl on New Year's Day.
    Most BBC stations phased out vinyl in favour of CDs in the 1990s and the majority now use digital versions of songs.
    According to the Beeb website, presenters Jarvis Cocker and Guy Garvey will be among those dusting off their turntables and Don Letts will be bringing his own seven-inch singles.
    The "All Vinyl" day rounds off a month-long celebration of vinyl.
    Station editor Paul Rodgers says: "In a world dominated by digital music, vinyl is a format still close to the hearts of many music lovers and increased sales demonstrate its enduring appeal."
    A spokeswoman for the station adds: "Listeners can expect rare gems, insights and a few crackles and pops when digital goes analogue for one day only."
    Singer-songwriter Richard Hawley will host a show talking to prominent acts such as Arctic Monkeys and Radiohead about the joys and the pitfalls of vinyl.
    Dance DJ and producer Andrew Weatherall and singer Cerys Matthews will also be joining the vinylfest in their shows.
  10. #547
  11. #548
  12. #549
    Lyra Atlas
    $9500
    Introducing the ATLAS, the world's first asymmetric MC phono cartridge.
    The Atlas is Lyra's new flagship. It is also the first time that anyone has made an asymmetrically structured phono cartridge. Why asymmetric? Because, by literally misplacing the barriers to great sound that are present in every other cartridge today, it confers a number of important performance benefits.
    First, having differently-shaped structures on the left and right sides suppresses the formation of standing waves inside the cartridge body, thereby creating a less resonant, more neutral cartridge body. Second, the asymmetric construction offsets the front magnet carrier and its associated mounting system so that it is no longer in line with the cantilever assembly. Doing so opens up a direct, solid path between the cantilever assembly and tonearm headshell so that vibrations from the cantilever can be quickly drained away once they have been converted into electrical signals, again suppressing resonances.
    Lyra remains the only cartridge manufacturer to mount the cantilever assembly directly into the cartridge body and thereby achieve a seamless, totally rigid connection between cantilever assembly and headshell. The effectiveness of this system has been increased with the asymmetrical structure of the Atlas. Control over spurious resonances is further assisted by the use of a narrowed mounting area, which couples the Atlas more tightly to the headshell and facilitates the transfer of vibrational energy into the tonearm.
    While the Atlas retains the yokeless dual magnet system, diamond-coated boron rod cantilever and variable-radius line-contact stylus of the Titan, the double knife-edge cantilever assembly mounting structure has been revised for greater rigidity, and the signal coil system is completely new. Rather than a square, the coil former is in the shape of an X, which allows each channel to operate with greater independence from the other. This gives better tracking, tighter channel matching, improved separation, and lower distortion due to crosstalk.
    At the same time we were able to increase both the performance and efficiency of the generator coils. The Atlas has 12% higher output voltage than the Titan, but accomplishes this while reducing the amount of wire in the coils by 22%. The mass reduction further improves tracking performance, while the enhanced output and electrical characteristics allow phono stages to perform better.
    The Atlas uses Lyra's "New Angle" technology, which mechanically pre-biases the signal coils so that they are perfectly aligned to the front and rear magnets when LP playback takes place. This equalizes out discrepancies in vertical and horizontal compliances, and enables the Atlas' coils to move with equal ease in all directions for optimal performance.
    As with the Titan and Olympos, the Atlas uses a body that is meticulously carved from a solid billet of titanium, through a process that involves both contact (for the exterior) and non-contact machining (for the interior body structures). But by making most of the Atlas' body surfaces non-parallel, avoiding dimensions that are multiples of other dimensions, and adding a pre-stressed phase-interference resonance-controlling system, resonances have been inhibited further.
    We firmly believe that the Atlas represents an important step forward in LP playback.
    Specifications
    Designer: Jonathan Carr
    Builder: Yoshinori Mishima
    Type: Medium weight, medium compliance, low-impedance moving coil cartridge
    Stylus: Lyra-designed long-footprint variable-radius line-contact nude diamond (3um x 70um), slot-mounted
    Cantilever system: Diamond-coated solid boron rod with short one-point wire suspension, directly mounted into cartridge body via high-pressure knife-edge system
    Coils: 2-layer deep, 6N high-purity copper, cross-shaped chemically-purified high-purity iron former, 4.2ohm self-impedance, 11uH inductance
    Output voltage: 0.56mV@5cm/sec., zero to peak, 45 degrees (CBS test record, other test records may alter results)
    Frequency range: 10Hz ~ 50kHz
    Channel separation: 35dB or better at 1kHz
    Compliance: Approx. 12 x 10-6cm/dyne at 100Hz
    Vertical tracking angle: 20 degrees
    Cartridge body: One-piece machining from solid titanium billet, with reduced-surface higher-pressure headshell contact area, predominately non-parallel and asymmetrical shaping, phase-interference resonance-controlling mechanism, and body threaded directly for mounting screws
    Cartridge mounting screws: 2.6mm 0.45 pitch JIS standard
    Distance from mounting holes to stylus tip: 9.5mm
    Cartridge weight (without stylus cover): 11.6g
    Recommended tracking force: 1.65 ~ 1.75g (1.72g recommended)
    Recommended load directly into MC phono input: 104ohm ~ 887ohm (determine by listening, or follow detailed guidelines in user manual)
    Recommended load via step-up transformer: 5 ~ 15ohm (step-up transformer's output must be connected to 10kohm ~ 47kohm MM-level RIAA input, preferably via short, low-capacitance cable)
    Recommended tonearms: High-quality pivoted or linear (tangential) tonearms with rigid bearing(s), adjustable anti-skating force, preferably VTA adjustment
  14. #550
