第53頁,共158頁 第一第一 ... 343515253545563103153 ... 最後最後
顯示結果從 521 到 530 共計 1578 條
  1. #521
    http://phasemation.com/html_eng/prod...g_pp-1000.html
    Y336,000
    Phasemation has started from cartridge development as an original point. The fruits researched and know-how accumulated since P1 release 10 years ago have been compiled; thereby we have realized the middle/treble sounds with the extremely fresh sound quality and rich bass sounds which are woven to the perfect harmony. Here, we will release the flagship MC cartridge PP-1000 of new brand “Phasemation”, as a new product different from conventional cartridge series.
    Redesigning the magnetic circuit
    The magnetic circuit of P-1G has been reconsidered in full scale; as a result, the shapes of front yoke and pole piece have been redesigned. Therefore, the shapes well suited for efficiency and magnetic uniformity have been successfully realized. It has been realized that the output is increased without increasing the mass of vibration section.
    Redesigning the body structure
    The material of P-1 body has been reconsidered from the beginning in order to get the best balance of sound quality. The materials of base and body have been respectively changed to stainless material and duralumin. Furthermore, DLC (Diamond Like Carbon) *1) coating is conducted; thereby, the sound quality being well suited for the rigidity and vibration-damping properties and being also suitable to be a flagship has been realized.
    *1DLC(Diamond Like Carbon)
    DLC(Diamond Like Carbon)is a generic name of carbon film to be produced with vapor phase synthesis utilizing ion processing; and the high rigidity and high electric insulation similar to a diamond are provided for it.
    Inheriting the high quality materials for audio sound
    High quality materials for audio sound verified in P-1G and other models are inherited; and they are well-acknowledged until now for the following parts:
    Cantilever made of pure boron material,
    Magneto coil, pure iron coil, bobbin and wire damper made of 6N oxygen-free copper wire, and others.
    Specifications
    Power Generation Method Moving Coil Type
    Impedance 4 Ohm
    Applicable Stylus Force 1.7 to 2.0g
    Output Voltage 0.29mV(horizontal direction of 1kHz 50mm/s)
    Compliance 8.0X10(e-6)cm/dyne
    Playing Frequency Range 10Hz to 30kHz
    Separation 30dB or more (1kHz)
    Channel Balance Within 1dB (1kHz)
    Range of Recommended Temperature 20℃ to 26℃
    Weight 14.3g
    Stylus Chip Diamond(line contact / curvature 0.03×0.003mm)
    Cantilever Pure Boron φ0.26
    Magnet Samarium Cobalt Magnet
    Magnetic Circuit Composition Material Permendur
    Base Stainless(Diamond Like Carbon processing)
    Body Duralumin(Diamond Like Carbon processing)
  2. #522
    感謝! 不知道 Target 原來可以這樣用
    LP 12 底板已經拿掉, 有聽說聲音會比較好
    訂了 24 x 18 x 2.25 吋的楓木切菜板, 準備架在(可能用 Cerapuc) 四角柱子上, 再放上 LP 12. 空間大些可以放一些道具.
    Target 四隻腳已經換成 Cerabase. 還在考慮要不要把 Target 灌沙. 有什麼建議嗎?
    引用 作者: philcoyuen 查看文章
    誠心建議,請將Target架的承板去掉。可將Linn12的底板也去掉直接在Target架的支撐架上面。這樣更能方便調整。而且聲音更能放開!Target架是尊為Linn12而設計製造。
  3. #523
    引用 作者: SGIREM463 查看文章
    另外Linn12是不能用重的唱片壓。調整轉盤的水平尤為重要!Linn12直接承放在支架上就好了。簡單就是The Best!!!!!
  4. The Following 2 Users Say Thank You to philcoyuen For This Useful Post:
  5. #524
    我相信 LP 12 會很好
    這兩天換上 Expert Stylus 或 Sound Smith Rebuild 的 Linn Troika 看看
    Lyra Argo 蠻好聽的. 據 Lyra 說, 像是個 Baby Titan.
    剛買裝上後就一直沒拿下來.
    引用 作者: Mell 查看文章
    Argo 和Skala相對的在細節和頻寬有很大的差距
    相信同樣的唱頭LP12也能表現的很出色
  6. The Following User Says Thank You to SGIREM463 For This Useful Post:
  7. #525
    這點有朋友頻頻告誡
    還是不信邪
    用了 300g 的 HRS Analog Disc, 約是 Platter + Sub-platter 的 10%, 或許不會有問題
    轉動慣量影響更小
    轉速正確
    唱片下有 Ringmat
  8. #526
    正在想買幾塊maple木板來放器材。能不能請教一下您的菜板是那裡買的?:P
  9. #527
    Amazon
    http://www.amazon.com/John-Boos-RA03...2943712&sr=8-1
    一個 USD $85, 約 60 x 45 x 6 CM
    maple 切菜板, 是木愧選擇紋路緊密的方向拼裝結合的, 強度可能比整片實木高.
    這種大眾市場的東西實在是便宜
    同樣規格的 Finite Elemente 或 BDR 可能要 USD $2000, 我覺得哪個好恐怕還很難說呢.
    此篇文章於 2011-12-04 07:58 AM 被 SGIREM463 編輯。
  10. #528
    謝謝!因為最近想把擴大機放到離喇叭近一點的地上,又不想直接放在地上。本來想去Home Depot買幾塊木板自己黏成厚一點的。現在有現成的更好!
    PS。會想到用楓木是看到這個 http://shop.mapleshadestore.com/Mapl...epartments/46/
  12. #529
    很多人說 Maple 聲音好. 應該錯不了.
  13. #530
    Benz-AMG
    BENZ AMG Viella 12 “V12” turntable
    Precision engineering and classic design are embodied in the first turntable from Benz AMG (Analog Made in Germany), the Viella 12 or simply, V12. The Benz AMG turntable line was created by a group of audio industry experts to advance the art of vinyl playback
    Werner Roeschlau, designer and driving force behind Benz AMG, works with his son and other master machinists at their bespoke multi-story Bavarian factory located north of Munich. All machining is done in house, combining the latest Computer Aided Design and CNC machines with “classic analog” tools including custom lathes and drill presses. Their factory has been manufacturing some of the world's most highly regarded turntables for over a decade. This expertise in the design and manufacture of turntables led to the Benz AMG line, premiering with the Viella 12.
    Viella Turntable Plinth:
    CNC machined in house using 25mm aircraft grade aluminum
    3 adjustable and retractable steel-copper spikes in aluminum feet
    Built-in spirit level
    Optional hardwood trim
    Viella Turntable Platter Bearing:
    Hardened 16mm axle bearing, CNC machined, ground and lapped Two sealed, hydro-dynamically lubricated radial bearings with axial bearings featuring static lubrication.
    Stainless steel sub-platter interfaces with 24.25 lbs (11Kg) platter
    Viella Turntable Platter:
    Decoupled spindle, 2 piece construction
    CNC machined in house using aircraft grade aluminum
    Weighted rim for enhanced flywheel effect
    12.5 “ (318mm) diameter, 24.25 lbs (11Kg) weight
    Viella Turntable Platter Clamp:
    True reflex style, anodized aluminum, inverted threaded attachment to decoupled spindle
    Viella Turntable Tonearm Board:
    Detachable high mass tonearm board, pre-drilled for Benz-AMG and Graham tonearms
    Viella Turntable Motor:
    Lorenzi 2 pulse, low-speed brushless, precision 24v DC motor with auxiliary reluctance moment; sintered bronze bearings; cured and polished axis; and heavy flywheel. Motor housing acoustically decoupled from plinth via 5 rubber/metal mounts.
    33.3, 45, and 78 speeds with electronic on/off, speed change, and speed fine adjust.
    Outboard Motor Power Supply with specific transformer for appropriate mains voltage and detachable IEC power cord
    Viella Turntable Belt Drive:
    Stainless steel weighted and polished drive-belt pulley.
    Precision made rubber belt.
    Viella 12” tonearm
    BEARING: Patented dual-pivot design (patent# 102007029039A1) also used in the rotor heads of helicopters. Horizontal axle with two 0.5mm thick “spring steel wires” replaces the standard gimbaled bearing, allowing fine azimuth adjustment while eliminating horizontal play. Vertical bearing is hardened tool steel, precision ground to a backlash-free fit with a needle roller bearing. It is extremely precise, maintenance free, and never requiring adjustment.
    ARMWAND: Aircraft quality, anodized aluminum tube for resonance control, 12 gram effective mass
    COUNTERWEIGHT: Two piece with Teflon decoupled sleeve
    COPPER INTERNAL WIRING: Multiple gauges of high quality copper
    MAGNETIC ANTI-SKATING: decoupled via a ring magnet and 2 bar magnets. Magnetic fields isolated in our patented bearing housing.
    VTA: precision locking system allowing easy adjustment during play.
    FULL WEB SITE COMING SOON
    http://www.benz-amg.net/
