第37頁,共158頁 第一第一 ... 2735363738394787137 ... 最後最後
顯示結果從 361 到 370 共計 1578 條
  1. #361
    最近買到的二手唱片
    很便宜,平均售價一張不到5美元. 今天收到的Olivia Newton-John的十來張唱片總共還不到40元(含運). 有好幾張根本沒開過.
    請問右下角倒數第2張AXE是那裡出版的?
  2. #362
    應該是美國版。等了好久才終於找到(就是想聽裡面的Battles和Forever)
    很多年前在台灣,我哥買過台版的,歌曲的順序都不同呢!
  4. #363
    不錯
    眾多好友都只有台灣版.羨慕.:P:P
  5. #364
    Hartvig TT Signature turntable
    89000 DKK
    The ultimate in music reproduction, high tech structure and build quality, with incredible high gloss polishes lacquer finish. The Hartvig TT Signature is the newest evolution in phonograph playback, and takes the classic analog medium to yet another level.
    Our endless listening sessions and strenuous tweaking, ensures music playback like no other, and widen the gap even further from the digital medias, with truly smooth and grain less analog sound. Opening the soundstage wider than ever, and keeping everything in completely control, our new platter and motor system is the absolute benchmark in its class.
    Precision microprocessors controlled motor system ensures stabile and precise rotation, and naturally flow of music.
    The platter and plinth is developed from the TT model, and brought up to a even higher level of precision tolerances, decoupling and advanced damping. And yet its all discretely hidden, inside the exclusive and clean looking design.
    Custom armboards, with wide array of setup alignment possibilities. We are stocking armboard for many of the most popular manufactures, and we are ready to make custom armboard for your favorite arm, on demand.
    Available in any finish or wood you like. Aluminum parts is available in anodised, polished or glass bead blasted surface finish.
    Clever clamp with tightening mechanism is included.
    HM Elektronik
  6. #365
  7. #366
  8. #367
  9. #368
    Yamamoto head shell
    Carbo HeadshellHS-4, HS-4S, Titanium HeadshellHS-5, HS-5S New Release
    HS-4 Carbon head shell (with standard lead) 12,000yen, HS-4S carbon head shell (with 6N copper lead) 16,000yen
    HS-5 Titanium head shell (with standard lead) 18,000yen, HS-5S Titanium head shell (with 6N copper lead) 22,000yen
  10. #369
    九家黑膠廠商
    萬片黑膠唱片
    難得一見華語、古典珍稀盤
    將從地下黑膠市集裡一一浮出
    時間:2010/03/05(五)~2010/03/14(日) 11:00-22:00
    地點:誠品敦南店B2
    誠品會員專屬挖寶日:2010/03/04(四) 11:00-22:00 (需出示誠品會員卡)
    主辦單位:誠品音樂
    合作單位:喫茶趣to go
    參展單位:
    誠品音樂、英倫經典、古碟唱片、亞德音響、音橋、Joy Audio、再聲工場、美藝、田昌政類比音響、李嘉宏 ● 活動期間內,單筆消費滿3000元,贈送誠品音樂85折黑膠折扣券一張 (使用規範請參照折扣券上說明)
    ● 活動期間內,於地下黑膠市集消費滿500元可獲得一點,累計滿10點可當場獲得抽獎機會一次
    (集點卡可於地下黑膠市集活動現場免費索取)
    延伸黑膠講座
    古典中的黃金Decca與爵士裡的Blue Note
    主講人:李商宇 (台北愛樂管弦樂團小提琴音樂家)
    時間:2010/03/07 (日) 15:00~16: 00 (免費入場)
    地點:誠品敦南店B2視聽室 (免費入場)
    從黃舒駿「馬不停蹄的憂傷」、「雁渡寒潭」黑膠發行
    談國語經典專輯黑膠唱片重刻的現況與展望
    主講人:江建德 (SMADI Records負責人) 、神祕嘉賓
    時間: 2010/03/07(日) 17:00-18:00
    http://blog.eslite.com/xinyi_music/archives/1891
  11. #370
    預設 sme20/3A与sme20/2A有什么区别?
    20/3 no arm £5750, 20/3A with gold writing V arm £8250
    The Model 20/3 is available in two formats:
    MODEL 20/3
    equipped for but not including SME precision pick-up arm.
    MODEL 20/3A
    as above but complete with matching SME Series V precision pick-up arm. Complete with a comprehensive set of tools and equipment including Height Setting Gauge, Ø300mm Stroboscopic Disc, Reflex Record Clamp, Record Spindle Washer, Soft Cover and Operating Instruction Manual.
    Dimensions: 440 x 350 x 172mm.
    Packing: Substantial case.
    Net weight with power supply: 31Kg (68lb)
    • Four point suspension for stability.
    • Sub-chassis suspended on eighty strands of rubber in the form of forty purpose moulded ‘O rings.
    • Suspension adjustable through trimmers used in conjunction with a gauge to give recommended settingsor varied to suit individual conditions.
    • Central fluid damper controls sub-chassis motion and offers resistive ground-path for acoustic signals.
    • Two screws lock down the sub-chassis and seal the damper for transport.
    • 19mm diameter main spindle machined from high - chrome steel, hardened, ground and super finished runs in a sealed oil bath for lifetime lubrication.
    • Screw down reflex record clamping system minimises record resonance.
    • 6.5Kg (14lb) platter with unique Isodamp face machined with a fine scroll for optimum record interface.
    • Generous use of extensional damping and resistive loop construction ensure sonic neutrality.
    • Optional mounting on steel ball feet or compliant inserts, both affording levelling adjustment.
    • Four jacking screws built into the sub-platter allow the thrust bearing to be off loaded for transit.
    • The Power Supply design incorporates a 4-layer surface mount technology pcb with on-board user adjustable speed variation control.
    • Large diameter strobe disc supplied allows precise adjustment of standard speeds.
    • Speed range: 33 1/3, 45 & 78 rpm.
    • Fully shielded in-line control unit. LEDs indicate themain functions
    www.sme.ltd.uk
    sme20/3A与sme20/2A有什么区别?在SME网站没有相关资料 ,可否介绍,谢谢!
