2010-08-17, 06:42 PM
#241
9折OK啦,有人買他應該就很爽了
我想您要擔心的是東西的品質有沒有問題,會不會很容易故障之類的
2010-08-17, 06:46 PM
#242
作者: 小葉
9折OK啦,有人買他應該就很爽了
謝小葉大大開示
原來外國店家也是可以砍價的喔
不過就如您說的,品質是不是穩定
不然和kuzma原廠(700USD,不連運)沒差很多時可能還是考慮原廠
2010-08-27, 11:22 AM
#243
TTWeights Audio GEM DC Rim Drive Turntable
http://www.ttweights.com/catalog/ite...59/8170410.htm
The new GEM turntable from Canadian manufacturer TTWeights Audio, priced at $4,959 promises to deliver truly extraordinary performance which exceeds that of turntables many times its price. Only the finest materials and most precise manufacturing techniques are used in the construction of the GEM. Its rim drive and other components use many of the lessons learned from the design of the company’s much more expensive Black ONYX turntable ($15,988 ).
The GEM includes the following components:
- one arm pod
- external motor DC servo drive with 4 spare drive o-rings
- controller with single power on - off and adjustable speed pot for 33/45/78 playback
- rotating turntable assembly
- copper mat
- center weight
The GEM turntable accepts any arm 9 inches and longer any wire configuration with DYI maple arm board on pod. A cartridge is not included. The GEM can be upgraded to use the same controller as its higher-end brother, the ONYX.
The TTWeights Audio GEM Turntable is available now for $4,959 (or $5499 with arm and cable).
www.ttweights.com
2010-08-30, 05:23 PM
#244
Adjust+
2010-08-30, 05:35 PM
#245
The Following User Says Thank You to chsiang For This Useful Post:
2010-08-31, 12:30 AM
#246
The "ANGEL OF MUSIC, CHRISTINE" Reference Series Turntable
2010-09-09, 09:18 PM
#247
2010-09-20, 02:48 PM
#248
聽黑膠時,碰到地震會???
小弟有個假設性疑問,如果唱片聽到一半發生地震,會有什麼問題?
針會斷掉嗎?
應該先關靜音還是把針舉起來?(嚴重的話當然是逃命先)
像clearaudio statement 這種磁浮唱盤,地震照成的影響會比較少嗎?
有前輩有經驗嗎?
2010-09-20, 03:42 PM
#249
.........ㄟ,我的意見是如果反應的過來,先把唱針舉起來吧
作者: E60M5
針會斷掉嗎?
有前輩有經驗嗎?
2010-09-22, 12:27 PM
#250
搞不好clearaudio statement 這種磁浮唱盤會更嚴重......
