第2頁,共5頁 第一第一 1234 ... 最後最後
顯示結果從 11 到 20 共計 41 條
    小葉 : 請問你本人有冇全部牌子試過 ? 請發表意見 如果沒有 你建議用誰張cd好??
  2. #12
    沒有特別去用,只試過幾張,基本上都還不錯 :)
    引用 作者: teaking 查看文章
  3. #13
  4. #14
    ALR JORDAN CD
    原廠網站
    www.alr-jordan.com
    ALR這套很值得買都非常好聽:)
  5. #15
    musk哥手上應該還有很多優的吧...:P
    去德國帶回來High End Society的CD都還沒拆,不知道錄音如何|(|-
    引用 作者: musk 查看文章
    ALR這套很值得買都非常好聽:)
  6. #16
    之前看樂音唱片有在賣High End Society,不過一直都還沒入手...
    乾脆等著我幫你的High End Society開苞好了~:P
  7. #17
    呵呵,我可是請High End Society的人幫我推薦幾張的
    原因很簡單,因為在那邊買太貴了,照訂價賣,沒辦法全買...;(
    帶過去沒問題啦...:o
    引用 作者: musk 查看文章
  8. #18
    個人比較常用的是Densen DeMagic與AYRE/CARDAS SYSTEM ENHANCEMENT DISC(大都用Track 7 Full Glide) [約每週同時使用這2張一次]
    Densen DeMagic另有一個不為人知的功用是可用來調整喇叭擺位進而調整相位
    "Irrational, But Efficacious", the System Enhancer Disc from Ayre Acoustics, Inc. is excellent in breaking in components and cables, integrating sub-woofers with other loud speakers and features both a short and full glide tone sweep. "Tune up" your system in under 20 minutes!
    The main tool is a five minute glide tone, that when played through your system at a moderately low listening volume, will improve its sound. While we don't have conclusive proof of the mechanism involved, we suspect that it functions by demagnetizing residual fields that build up in your components over time. We recommend playing this track on a periodic basis, from perhaps once a week to once a month. We put this track at the end of the disc so that it can be easily played even if the system is unattended. The other tracks have more specialized functions.
    The tracks on this disc were created digitally with 88.2 kHz, 32-bit resolution. Enhanced resolution transfer to the 44.1 kHz, 16-bit CD format was performed using 0.5 bits of dither with a triangular probability distribution function for maximum fidelity.
    Selections:
    Short Glide Tone: This 60-second track contains a 45-second glide tone that sweeps from 5Hz to 20kHz, preceded by 5 seconds of silence and followed by 10-seconds of silence. This track offers a quick system "tune-up" for those times when you just can't wait five minutes for the full glide tone.
    White Noise: Uncorrelated stereo white noise with a peak level of -12 dB. White nosie is purely random in nature and is chiefly used with test instruments for specialized measurements. The track lasts for 180 seconds and features a 2-second fade in and fade out.
    Pink Noise: Uncorrelated stereo pink noise with a peak level of -6 dB. Pink noise is low-pass filtered to achieve equal energy in each octave, and is also commonly used with test instruments for specialized measurments. The track lasts for 180 seconds and features a 2-second fade in and fade out.
    Brown Noise: Uncorrelated stereo brown noise with a peak level of -3 dB. Brown noise is low-pass filtered to closely mimic the spectral distribution of music. This signal is excellent for use in breaking-in components and cables. The track lasts for 180 seconds and features a 2-second fade in and fade out.
    Mono Brown Noise: Identical noise signals in both channels. This track can be very useful when integrating sub-woofers with other lous-speakers. The track lasts for 60 seconds and features a 2-second fade in and fade out.
    Out-Of-Phase Brown Noise: Opposite-polarity brown noise signals in each channel. This track can be used to minimize the actual sound levels when breaking-in equipment, due to acoustic cancellation between the channels. The overall sound level will be minimized when two loudspeakers are placed as close together as possible.
    Full Glide: This 300-second track contains a 285-second glide tone that sweeps from 5Hz to 20kHz, preceded by 5 seconds of silence and followed by 10 seconds of silence. Please be sure to play the entire track without interruption. Try it, you'll like it!
    LP則使用CARDAS MK2 FREQUENCY SWEEP AND BURN-IN RECORD
    The Cardas Frequency Sweep and Burn-in Record is a unique tuning tool for system set-up, diagnostics and maintenance. It was produced by George Cardas and mastered by Stan Ricker. The "Sweeper", in addition to the standard tones, includes relative and absolute polarity checks, vocal channel identification and frequency sweeps that ultrasonically clean the cartridge stylus and degauss the entire system. And, locked, pink noise grooves that repeat endlessly, blank plateaus, even a sync label to check platter speed. All on a 180 gram pressing with a smiling Stan cover.
    Selections (Sweeper):
    1000 cycles, -14db
    Sweep 30Hz to 30KHz, -14db, 2 ch., in phase
    Sweep 1KHz to 30KHz, -14db, 2 ch., out of phase spiral
    Sweep 1KHz to 30KHz, -14db, 2 ch., out of phase lock out
    10KHz, -14db, 2 ch., in phase
    10KHz, -14db, left channel
    10KHz, -14db, rich channel
    1KHz triangle wave, -14db, 2 ch., in phase
    1KHz, -14db, 2ch., in phase
    1KHz, -14db, left channel
    1KHz, -14db, right channel
    400Hz, -14db, 2 ch., in phase
    400Hz, -14db, left channel
    400Hz, -14db, righ channel
    65.4Hz, 2 ch., in phase, lock out
    65.4Hz, 2ch., out of phase, spiral
    49Hz, 2 ch., in phase, spiral
    49Hz, 2 ch., out of phase, lock out
    1KHz, "0"db for level set.
    Selections (Burn-In):
    Greetings from left channel
    Greetings from right channel
    Greetings from both channels
    In Polarity, both channels, positive polarity
    Out of Polarity, both channels in negative polarity
    13 strikes on a high "B-Flat" on a piano
    Hollow sticks (various length and diameter) being struck against each other
    20 locked grooves, lateral modulation (mono)
    32 locked grooves, vertical modulation (out of phase)
    26 unmodulated grooves.
  9. #19
    還有一張聖經Chesky ULTIMATE DEMONSTRATION DISC (不過這張我很少使用)
    Reading about transparency or focus will only take you so far, the Ultimate Demo Disc serves as an aural dictionary by cueing the listener to specific sonic qualities of each selection. By consistently using the Disc, hearing & understanding these terms will become so much easier. The Disc can be used to evaluate speakers, receivers, preamps, power amps, CD players, digital to analog convertors, even cables. Artists on this disc include: Rebecca Pidgeon, Ana Caram, Leny Andrade, Sara K., Monty Alexander, Johnny Frigo, Fred Hersch Trio, Livingston Taylor, & more! Demo's include: High Resolution, Transparency, Holographic Imaging, Focus, Midrange Purity, Depth, Transients & many more!
    Features:
    • High Resolution Technology - 128x Oversampling
    Selections:
    1. Welcome to the Ultimate Demonstration Disc
    2. High Resolution - Introduction
    3. Spanish Harlem - Rebecca Pidgeon
    4. Depth - Introduction
    5. If I Could Sing Your Blues - Sara K.
    6. Atmosphere - Introduction
    7. Maiden Voyage - Leny Andrade
    8. Midrange - Introduction
    9. Grandma's Hands - Livingston Taylor
    10. Naturalness - Introduction
    11. Correnteza - Ana Caram
    12. Transparency - Introduction
    13. Played Twice - The Fred Hersch Trio
    14. Presence - Introduction
    15. Ask Me Now - McCoy Tyner & Joe Henderson
    16. Visceral Impact - Introduction
    17. Sweet Georgia Brown - Monty Alexander
    18. Rhythm & Pace - Introduction
    19. I Love Paris - Johnny Frigo
    20. Focus - Introduction
    21. Vivaldi's Flute Concerto in D - performed by the Connecticutt Early Music Festival Ensemble
    22. Holographic Imaging - Introduction
    23. Britten's Festival Te Deum - performed by the Westminster Choir
    24. Transients - Introduction
    25. Stravinsky's The Royal March - performed by Solisti New York conducted by Ransom Wilson
    26. Bass Resonance - Introduction
    27. A Selection from Best of Chesky Jazz and More Audiophile Tests, Volume 2
    28. Dynamic Test - Introduction
    29. A Selection from Best of Chesky Jazz and More Audiophile Tests, Volume 2
    30. Final Announcement
  10. #20
    另一張 CHESKY/STEREO REVIEW GOLD STEREO & SURROUND SET-UP DISC CD
    Stereo Review and Chesky Records have teamed up to help maximize the performance of your home stereo or home theater system with audiophile tests illustrated by selections from the finest music Chesky has to offer.
    This Set-Up Disc from Chesky Records is mixed from a Gold master. Producing from a Gold master features less noise jitter and a purer sound!
    Selections:
    1. Introduction
    Section One:
    2. System Phase
    3. Phase Test Intro
    4. Phase Test
    5. Music Intro
    6. Under The Table - Rebecca Pidgeon
    Section Two:
    7. Stereo Speaker Setup
    8. Channel Balance Test Intro
    9. Channel Balance Test
    10. The Stepped Stereo Pan Test Intro
    11. The Stepped Stereo Pan Test
    12. Music Intro
    13. Agua De Beber - Ana Caram
    Section Three:
    14. Subwoofer Setup
    15. The Subwoofer Level Matching Test Intro
    16. The Subwoofer Level Matching Test
    17. Shake, Rattle, And Roll Test Intro
    18. Shake, Rattle, And Roll Test
    19. Music Intro
    20. Leather Cats (excerpt) - Oregon
    Section Four:
    21. Imaging and Soundstaging
    22. General Image and Resolution Test from The Best Of Chesky Jazz and More Audiophile Tests Volume 2
    23. Music Intro
    24. Piano Concerto No. 27 - Allegro (excerpt) - W.A. Mozart
    25. Music Intro
    26. Psalm 24 - Lili Boulanger and the Westminster Choir
    Section Five:
    27. Room Acoustics and System Response
    28. The Clap Test Intro
    29. The Clap Test
    30. The Wandering Audiophile Intro
    31. The Wandering Audiophile
    32. Music Intro
    33. Pau Brasil - Badi Assad
    34. Aires Del Poliogono - Carlos Heredia
    Section Six:
    35. Home Theater System Check
    36. Dolby Pro Logic Circular Pan Test Intro
    37. Dolby Pro Logic Circular Pan Test
    38. Dolby Pro Logic Center To Surround Pan Intro
    39. Dolby Pro Logic Center To Surround Pan
    40. Dolby Pro Logic Channel Identification Intro
    41. Dolby Pro Logic Channel Identification
    42. Theater Without Pictures Intro
    43. The Soldier's Tale - Joseph Laments his Fate - Igor Stravinsky (Solisti New York)
    Section Seven:
    44. The Music Tests
    45. Theme From I Love Lucy - Paquito D'Rivera
    46. Music Intro
    47. Gadamaylin - I Ching
    48. Final Announcement
