第21頁,共22頁 第一第一 ... 1119202122 最後最後
顯示結果從 201 到 210 共計 215 條
  1. #201
    我是去年2015 8月買的luna 6 ex,電池這兩天才買,在搬動機器時突然才發現power supply後面有個開關,旁邊貼紙描敘如下
    groundlift - switch
    connects the power-ground with the audio-ground
    open connected
    照著翻譯好像是跟接地有關,請問有前輩知道是幹嘛用的,能回答一下嗎?謝謝!
    我試著開關沒感覺有變化,
  2. The Following 2 Users Say Thank You to godwind For This Useful Post:
  3. #202
    1的位置,電源接地會與訊號來源接地(RCA input)串在一起, 一般都要設在1,如果設在1有哼聲,才設定到0,把接地切掉
    The ground lift switch is located on the back panel of the ASR Emitter above the AC input.
    Switching to position „1“ will connect the ground of the power supply to the ground of the connected source components (on the RCA inputs). Audio ground should be once connected to the power supply ground in every audio system. If connected more often hum can occur. Switching to position „0“ disconnects the ground connection as described above.
    In any doubt: please switch the ground lift switch to „1“.
    Post from tapatalk app
  4. #203
    住址
    A, A
    煩請站長開示這樣正確嗎?
  5. The Following 2 Users Say Thank You to Michael Lin For This Useful Post:
  6. #204
    應該對的,但可以試試那個檔位您覺得比較好聽嘍
  7. The Following 2 Users Say Thank You to Leo Yeh For This Useful Post:
  8. #205
    瞭解了,感謝小葉大,再來聽看看有沒有差
  9. The Following 2 Users Say Thank You to godwind For This Useful Post:
  10. #206
    我以為是電源總開關,常有疑問關掉了 怎麼還可以聽:)
  11. The Following 2 Users Say Thank You to knicks For This Useful Post:
  12. #207
  13. #208
  14. #209
    請問LUNA8的節能模式如何關閉.
    謝謝!
  15. The Following User Says Thank You to MARK For This Useful Post:
  16. #210
    看英文說明書~~~~~~~~~
  17. The Following User Says Thank You to snkhsu For This Useful Post:
