第76頁,共77頁 第一第一 ... 266674757677 最後最後
顯示結果從 751 到 760 共計 761 條
  1. #751
    版主求救: 小弟的 embla 壞了驅動盒。 但在香港沒法維修, 要寄這種東西入中國,比較麻煩。不知台灣這邊有沒有可以維修的呢?
  2. #752
    你好,我叫克里斯,我是從波蘭寫的。我為語言道歉,但我使用翻譯。我幾天前買了一台Bladelius Embla DL播放器。在第一天,顯示屏根據設備背面的標籤顯示序列號和MAC地址。但是,第二天顯示屏顯示全部為零,互聯網無法正常工作。是否有任何硬重置程序或再次上傳軟件?我問製造商,但他沒有回答。
  3. #753
    引用 作者: Chris PL 查看文章
    Sorry no idea to solve your problem, the best way is still to contact Bladelius.
  5. #754
    Embla is already ok. What would you recommend to her, I currently have Thor MK2, I think I change to something better. Would the Thor MK3 or Idun + Balder be better (I do not want to use the preamplifier in Embla because I prefer in the standard mode without a preamplifier inside the Embla). I do not want Ymer or Tyr, just Thor MK3 or Idun + Balder MK1. What are you doing? What is the difference between Thor MK2 and MK3?
  6. The Following User Says Thank You to Chris PL For This Useful Post:
  7. #755
    Thor MK3 has more power, but I don't think you have to upgrade from MK2.
    Same price range preamp + amp will be better than integrated, but not too much.
    I suggest you to upgrade higher level, that will be much better.
  9. #756
    叶版主您好,想请教一下,embla自行升级固态硬盘的话有什么要求吗?我之前买过一款七彩虹720G的固态硬盘,但是不兼容无法使用
  10. The Following User Says Thank You to sands For This Useful Post:
  11. #757
    引用 作者: sands 查看文章
    已經很久了,我覺得這個回到技術面,應該是要完全一樣的硬碟格式(NTFS、FAT32與exFAT )與作業系統移植
  12. #758
    引用 作者: Leo Yeh 查看文章
    I've sent email to Bladelius as well but no response. Are they still in business?
    Sent from my MHA-L29 using Tapatalk
  13. #759
    哦,我看自带的固态硬盘上面也没有作业系统啊,但是就可以正常使用
  14. #760
    现在还有embla的用家吗?能分享一下怎么给内置的固态硬盘扩容吗?
