第1頁,共58頁 1231151 ... 最後最後
顯示結果從 1 到 10 共計 573 條
    預設 【賞心悅目】分享一切美的人事物
    版規:嚴禁露點
    (真的忍不住的請"私下"email給我)
    Lamborghini Murciélago LP 670-4 SuperVeloce
    an increase in power to 670 hp and 487 lb-ft of torque for Lambo's 6.5L V12
    a weight decrease of 220 lbs and performance figures begin to fall fast. 0-62 mph is now achieved in just 3.2 seconds and top speed is 212 mph with the standard
    http://www.autoblog.com/2009/03/02/officially-official-lamborghini-murcielago-lp-670-4-superveloce/
    Concord C1 QuantumGravity
    Technical Features:
    Movement
    Mechanical manually wound movement
    Caliber Concord C104
    21,600 vibrations per hour
    3-day power reserve
    42 Jewels
    Functions
    Hours, minutes
    Roll of seconds external to the case
    Vertical power-reserve indicator
    Bi-axial tourbillon
    Case
    Titanium case with white gold elements
    Dimensions: 48.5 mm in diameter – 22 mm in depth
    5 sapphire crystals
    See through officer-style hinged case back
    Dial
    Aerial skeletonized dial
    Strap
    Black vulcanized rubber fixed to the case with 4 screws
    http://www.c1-quantum.ch/themakingof/
    Ulysse Nardin Chairman hybrid smart phone
    The Chairman is the relentless pursuit of uncompromising quality. It is the embodiment of improvement through evolution. This hybrid smart phone is symbolic of the enduring success that will drive Ulysse Nardin to the forefront of the industry for generations to come. The Chairman, much like its owner, is the complete expression of dedication, passion and excellence.
    2.8" multi-touch screen
    Fingerprint reader for owner identification and phone lock
    Numeric keys with high quality tactile response
    E-mail and Internet application
    5 megapixel camera
    Wi-Fi for network connection
    Sapphire Glass
    18k rose gold
    Kinetic rotor system
    www.uncells.com
    同樣是車子~~極便宜與極貴都粉美好~~~~~~~:O
    全世界最便宜車上市 7萬元有找
    更新日期:2009/03/23 21:01
    全世界最便宜的汽車,在今天正式量產上市,一輛車台幣7萬元有找!這是由印度塔塔集團推出的新款國民車NANO,這輛車可以塞4個人,不過因為價格便宜,汽車裡面沒有音響,也沒有冷氣,更沒有安全氣囊,只是價格比摩托車貴不了多少,預料將在印度產生一場新的交通革命。
    全世界最便宜的汽車,就是它!來自印度塔塔集團的NANO國民車,看起來和一般汽車差異不大,長3.1公尺、寬1.5公尺、高1.3米,後輪驅動設計,加大座艙空間,圓圓的車身,恰好可以坐進4個人,已經在印度車市成為話題。 印度購車民眾:「我很開心,我本來有摩托車,我會賣掉摩托車,改買NANO,因為我全家人都可以坐進去。」 來自印度的新款國民車,走低價策略,一部起價美金2050元,折合台幣不到7萬元,在印度,只要你買得起2台摩托車,就一定買得起NANO。市場分析師偉嘉:「我非常確定塔塔汽車集團,將會得到巨大成功。」
    這款國民汽車雖然沒有冷氣、沒有收音機、沒有防盜鎖,也沒有安全汽囊,只有在印度才買得到,衝著它不到7萬元的超低價,已經讓印度原本只買得起摩托車的兩輪族,蠢蠢欲動,預計會在印度掀起一場交通革命!
    周董的超級生日禮物Lamborghini Reventon
    【 CARNEWS 文/羅文杰 責編/杜嘉豪 】
    周杰倫在30歲生日會中許下心願:擁有全球限量20輛的Lamborghini Reventon。一般人對於此車的所知不外乎很稀有、很昂貴,筆者的看法差不多,只要再加一點,這是一場數字遊戲!
    對普羅大眾而言,金錢的作用是滿足生活所需,一旦需要付出高額花費,不免要停下腳步,評估這筆交易的可行性。鏡頭轉入金字塔頂端,對於財力雄厚的人來說,金錢的作用早已不是吃飽穿暖,說穿了,金錢只是數字。接觸超跑買家的經驗告訴我們,現代有錢人購買奢侈品的用意不見得是揮霍(硬著頭皮貸款買車的人,這才叫做揮霍!);也不一定是炫耀(手中卻保有炫耀的本錢)。
    選購超跑的思維其實簡單,就是要將這些數字(是數字,不是錢)發揮到什麼程度?拿這些數字能換取什麼?(也許是虛無,也許是實際)。此外,在歐美日本等成熟市場,擁有限量超跑不只是蒐藏、貪快,也是一門投資。愈是稀有、屌傲,增值空間愈高…。
    數量極度稀少
    全球僅生產20輛
    發表於2008年車展的Lamborghini Reventon售價一百萬歐元,在近代超跑的價位排行榜名列前茅,與Bugatti Veryon 16.4、Ferrari FXX、Koenigsegg
    CCX-R同為第一集團。就商業角度來看,Lamborghini Reventon是最值得投資的超跑,原因何在?首先,Lamborghini Reventon只造一批,總生產數量只有20輛,相較於其他超跑無疑是稀世珍寶。其次,Lamborghini Reventon具有相當可觀的增值空間,一些買家在到手之後第一個動作不是上路兜風,而是裝箱封存。假如你是Air Jordan的收藏家,就可以理解這種行為的意義。
    也就是說,你無須擔心周董買不到新車,即使20輛早已銷售罄空,透過專業管道,還是可以買到未上路的Lamborghini Reventon,只不過,代價比原價更高,據悉,目前全新Lamborghini Reventon的價格至少增漲兩成以上,絕不是8,800萬台幣可以弄到手的。
    價格極度昂貴
    一百萬歐元起跳
    所以說Lamborghini Reventon是值錢的投資品絕不為過,原因是獨特(光是這一點,周媽媽就不該反對了…給他買、給他買!)。這款特殊版本的設計工程全由Lamborghini一手包辦,絕無委託外部的汽車設計公司執行。Lamborghini Reventon誕生於蠻牛的故鄉Sant’Agata Bolognese,設計部份由Lamborghini’s Centro Stile (Style Centre)操刀,這裡是Lamborghini的精銳核心,擁有最齊全的CAD電腦輔助設施,以及完整的測試裝備。設計案完成之後,再交給Lamborghini Research and Development Department進行更深入的測試以及細節潤飾。動力方面,Lamborghini Reventon採用的是Murcielago LP640的V12引擎,再將動力強化至650hp,絕對值得台幣8,888萬元!
    採用戰鬥機座艙介面為設計靈感,不論有形的材質、用料甚至是無形的科技感都屬頂尖。
    眾所皆知,Lamborghini Reventon的概念源自戰鬥機,因而呈現出航太元素的造型。除了車頂與車門外鈑件,所有車身材質均採用CFC碳纖維複合材質,質輕剛強。頭燈為氙氣頭燈,佐以LED輔助燈具,車尾也加入特殊耐熱設計的LED,以免除引擎高溫的傷害。內裝方面,由反皮、碳纖維、鋁合金三種組合而成,最值得一提的是顯示儀錶,位居駕駛者正前方的TFT液晶螢幕可以傳達多種訊息,除了必備的車速、轉速、油壓、油溫、水溫、油量外,還包含一顆G力顯示錶,這顆儀錶的作用或許不是用來察知車輛可以快到什麼程度,而是檢視人體的承受極限,以免呸到一半、駕駛卻暈了過去。
    除了外型內裝深具戰鬥機的元素,就連採用的漆料也要講究。原廠表示,Lamborghini Reventon採用的顏色為不透明、綠/灰混搭的特殊顏料,你以為這是死板的平光漆?錯,這是一種活生生的漆料,能隨著光線強弱產生色階變化,到了白天,顏色會加深,大有隱形戰機的意味,這裡又增添了它的價值。
    數位化儀錶?戰鬥機駕駛員應該會很熟稀。只差沒有武器切換顯示幕而已!
    數字遊戲
    有錢未必買得到
    在歐洲,花100萬歐元可以選擇一部千匹馬力、極速四百的Bugatti Veyron16.4,也可以買Ferrari的FXX,在專業賽道上接受專業車手的教導與技術團隊的調校。前者的生產數量偏高,後者又顯得麻煩。Lamborghini Reventon的好處是實際,即使限產20輛,仍不忘本。Lamborghini Reventon的核心價值仍為實用,與其他Lamborghini一樣,Lamborghini Reventon不只是奢侈品,更可以拿來日日通勤、天天服用。
    來自LP640的V12引擎,最大出力已調整至650hp/67.35kgm!
    至於台灣,超跑的易手價有行無市,更說不上投資;關於周董,筆者建議還是低調些、聽媽媽的話,購買這類屌車招來的閒話多於祝福(假如要招來話題,那又另當別論),假如時光倒轉,最好將Lamborghini Reventon列為吹完蠟燭後第三個-不能說的願望,自己知道、悄悄實現就好。
    Lamborghini Reventon規格表
    引擎型式
    V12 DOHC 48V
    排氣量
    6496c.c.
    缸徑×衝程
    88.0×89.0mm
    壓縮比
    11.0:1
    最大馬力
    650hp/8000rpm
    最大扭力
    67.35kg.m/6000rpm
    懸吊系統
    前、後雙A臂
    電子輔助
    ABS/ASC+T
    輪胎規格
    前245/35R18 後 335/30R18
    傳動方式
    4WD
    變速系統
    e-gear六速自手排
    Gear
    Ratio
    1st
    3.091
    2nd
    2.105
    3rd
    1.565
    4th
    1.241
    5th
    1.065
    6th
    0.939
    煞車系統
    四輪碟煞
    長/寬/高
    4700/2058/1135mm
    軸距
    2665mm
    輪距
    前1635/後1695mm
    空重
    1665kg
    0∼100km/h
    3.4秒
    極速
    340km/h以上
    售價
    100萬歐元
    dickson2000 訪客
    dickson2000 訪客
    全民寧靜運動-----萬人禪修
    http://2009zen.093.org.tw/
    dickson2000 訪客
