第262頁,共268頁 第一第一 ... 162212252260261262263264 ... 最後最後
顯示結果從 2,611 到 2,620 共計 2677 條
  1. #2611
  2. #2612
  3. #2613
    隨便貼幾張
    荷蘭名畫家林布蘭的自畫像(局部特寫)-- 原圖在華府的國家藝廊
    今天早上下冰雨,結在樹枝和樹叢上的冰
    今年冬天,美東可真是冷啊!
  4. The Following 2 Users Say Thank You to kevintran For This Useful Post:
  5. #2614
    宿舍附近的一家つけ麺店
  6. The Following 2 Users Say Thank You to kid1002 For This Useful Post:
  7. #2615
  8. #2616
    Canon PowerShot G1 X Mark II Digital Camera
    搭載1.5吋新型CMOS感應元件,5x ZOOM LENS,Wi-Fi,觸控式LCD螢幕
    Canon just announced its new $800 flagship compact camera, PowerShot G1 X Mark II, which replaces last year’s G1 X digital camera. The new Mark II offers a sensor that is 4.5x larger than a 1/1.7″ sensor found in professional level point-and-shoot cameras. Its new type of 1.5-inch, 12.8 megapixel High-Sensitivity CMOS sensor, made by Canon, allows for optimum performance with an ISO range of 100-12800. This sensor, combined with the DIGIC 6 Image Processor, comprises the Canon HS SYSTEM resulting in faster autofocusing speeds over the PowerShot G1 X camera, allowing photographers to capture detailed, vivid images even in low-light conditions.
    Featuring a newly-developed f/2.0 – f/3.9, 5x optical zoom lens (equivalent 24-120mm zoom range) with Dual Control Rings, this new camera provides customized zooming and focus-functionality similar to a DSLR camera. With this wide of an aperture, photographers have the ability to isolate their subjects by separating them from a background that is blurred. This gives more control and creative possibilities when using a PowerShot camera. The Dual Control Rings include a Step Ring to adjust various customizable settings and a Continuous Ring to make focusing adjustments during manual focus, as well as additional customizable settings for manual shooting. The new lens also features a nine-blade aperture to provide beautiful, blurred backgrounds even at full-zoom range.
    Improved Operation and Performance
    The PowerShot G1 X Mark II camera has a default aspect ratio of 3:2 which is the same ratio the advanced user has come to expect when shooting with a DSLR camera. If the photographer wants to switch to a 4:3 ratio, it can be done without impacting the field of view.
    The new PowerShot G1 X Mark II camera uses 31 Auto Focus (AF) points, compared to the PowerShot G1 X camera that uses nine AF points, resulting in improved autofocus capabilities allowing the user to easily compose the image and focus on a specific subject in the frame. Utilizing the bright, capacitive touch, three-inch tilt LCD on the PowerShot G1 X Mark II camera helps provide flexibility in shooting by tilting 180 degrees up and 45 degrees down.
    The PowerShot G1 X Mark II camera is also compatible with Canon’s new optional electronic viewfinder that mounts to the hot shoe. A new optional grip will also be available for the PowerShot G1 X Mark II camera. These accessories are ideal for photographers looking for the feel of a DSLR camera with the portability of a point-and-shoot camera.
    Seamless Connectivity
    The PowerShot G1 X Mark II camera is equipped with built-in Wi-Fi technology, so users can share still images and videos online quickly and easily using compatible mobile devices. Using the Mobile Device Connect button, users can connect to a smartphone, a tablet or a Wi-Fi enabled computer. Connection to the computer is easily done using Canon iMAGE GATEWAY 2 through the cloud. For even easier connectivity, the PowerShot G1 X Mark II camera introduces Near Field Communication (NFC) – a first for Canon’s G-series cameras – so transferring photos to a compatible Android device can be simple and intuitive. This digital camera’s new remote shooting feature also allows the user to sync the G1 X Mark II with a smartphone or tablet and utilize the shutter, optical zoom and self-timer features from that device.
    Extensive Shooting Modes
    Ideal for portrait photography, the camera’s Background Defocus mode softens the background behind a subject to help users create professional-looking portraits. In addition, simply pressing the camera’s dedicated movie button allows photographers to capture 1080p Full HD video with ease. And, as commonly found in most DSLR cameras, the PowerShot G1 X Mark II camera has a full range of shooting and recording modes, including 14-bit RAW + JPEG, for outstanding creative control.
    Unique to Canon PowerShot Digital Cameras, the PowerShot G1 X Mark II camera features Advanced Star Mode with four options to capture images of starry night skies with impeccable quality. The “Star Portrait” and “Star Nightscape” modes help capture the radiance of stars while still allowing you to capture the subject. The “Star Trails” mode captures video trails of stars to turn trails into a luminous still image, while the “Star Time Lapse Movie” mode will shoot images of star movement and then combine the images to make a film that shows the movement of the stars, creating a truly stunning video.
    Availability
    The Canon PowerShot G1 X Mark II digital camera will be available April 2014 for $799.99.
  9. #2617
    SONY α6000
    世界最快自動對焦速度0.06秒,179點對焦AF傳感,幾乎涵蓋所有範圍。
    搭載EXMOR APS HD CMOS,24.3萬有效像素。APS-C大尺寸數位傳感器,新影像處理BIONZ X。
    直觀操作,可調整變更設定值按鈕。配備OLED Tru-Finder。
  10. #2618
  11. #2619
  13. #2620
    預設 Canon EOS Rebel T5 Digital SLR Camera
    Canon發表新的入門級數位相機EOS Rebel T5 (EOS 1200D),18萬像素CMOS感應器、DIGIC 4影像處理、ISO 100-6400(最高可擴展至12800)、自動9點對焦系統、3吋LCD顯示螢幕、對於行動中的物體擁有優異的連拍捕捉能力(3 fps),並且非常適合近距離拍攝,還有1080p的高畫質影片拍攝。
    http://www.canon.com
