第253頁,共268頁 第一第一 ... 153203243251252253254255263 ... 最後最後
顯示結果從 2,521 到 2,530 共計 2677 條
  1. #2521
    Panasonic DMC-G5 Lumix Micro Four Thirds Digital Camera
    Share on emailShare on twitterShare on facebookShare on googleMore Sharing ServicesShare
    Posted by Admin on July 18, 2012 - Reply
    Panasonic today announced the LUMIX DMC-G5 Digital Single Lens Mirrorless (Micro Four Thirds) camera offering a new 16.05-megapixel Live MOS sensor and redesigned Venus Engine to render clear, crisp images in both photo and video recording. Featuring a compact, lightweight body with built-in flash, the LUMIX G5 boasts ultra-high mobility while offering users powerful camera performance and better image quality over its predecessor, the LUMIX DMC-G3. New features include a better LCD screen, faster burst shooting, greater ISO, and improved video recording.
    The LUMIX G5's high-grade lens and precision AF (Auto Focus) achieves high resolution, optimal balance of resolution and noise reduction to produce lifelike image rendering and high precision auto exposure and white balance for faithful color reproduction. A redesigned Venus Engine features exceptionally advanced signal processing capabilities, producing clear, crisp images in both photo and video recording. The 3DNR detects smooth areas or edges in photos and adjusts the strength of noise reduction (stronger for smooth portion, milder for edge portion) to maintain object descriptiveness. The Multi-process NR quickly detects brightness in each part of a picture and applies optimal noise reduction in multiple steps. The newly incorporated HDR (High Dynamic Range) allows for several pictures consecutively shot at different exposure levels to be overlaid, producing a single composite picture to eliminate over-exposure or under-exposure.
    Like all cameras in the LUMIX G series, the LUMIX G5 adopts Contrast AF (Auto Focus), so focusing is controlled by the image sensor. Compared with the Phase difference system AF, Contrast AF boasts higher accuracy, especially when shooting with a bright lens with small F values. To further advance the Contrast AF, the G5 incorporates full-area Touch AF, making it possible to set the focus on any point in the field of view. Additionally, ultra high-speed Light Speed AF, quickly locks onto a subject, making it possible to capture even fast moving subjects clearly. Combined with Touch AF control and high-speed burst shooting at six frames per second in 16.05-megapixel full resolution captures fast-moving objects clearly.
    The LUMIX G5 adds a new function lever conveniently located near the shutter release allows for direct adjustment of zoom, exposure or aperture control and can be used to magnify images in playback mode and page flip in menu mode. Additionally, the combination use of the function lever and turn-and-push rear dial allows users to adjust major shooting settings, accelerating the camera's simple, intuitive operation.
    The LUMIX G5's large, bright 1,440,000-dot equivalent LVF (Live View Finder) retains outstanding viewability and features approximately 100% field of view. Suppressing color breakup, the LVF assures stunning image view for any subject or scene. The LVF is newly designed to integrate an eye sensor for the LUMIX G5, which allows image output between the LVF and LCD screen to be switched automatically with the eye sensor on the LVF (which features optional sensitivity of high, low and off). Additionally Eye Sensor AF (Auto Focus) automatically starts focusing when the photographer looks into the EVF to capture spur-of-the-moment shooting opportunities.
    A large, 920,000-dot high resolution LCD screen with wide-viewing angle rotates 180 degrees to the side, tilts 270 degrees up and down and offers approximately 100% field of view. Touch screen operation on the LCD screen allows for simple shooting or playback of images and the new Touch Pad function enables the use of both LVF and LCD simultaneously, which encourages more intuitive shooting. Lag time of image output has been minimized by approximately 18% compared to the LUMIX G5's predecessor, the LUMIX G3, making it easier to monitor fast-moving subjects. The Level Gauge give the camera the ability to automatically detect the horizontal or vertical angle of view so that photos shot in a portrait aspect will automatically be displayed vertically, no matter which lens is used. The newly added Electronic Shutter mode allows silent operation which is helpful in areas where silence is needed.
    Creative Control Mode has been upgraded in the LUMIX G5 with an increase of filter options from five options to 14, adding Soft Focus, Dynamic Monochrome, Impressive Art, One Point Color, Cross Process, Low Key, Toy Effect and Star Filter, in addition to the conventional Expressive, Retro, High Key, Sepia, Hi Dynamic, Miniature Effect modes. With the new GUI menu tab, switching filter effects is seamless. A preview of filter effects can be seen on the large LCD screen via Live View mode and the camera intuitively recommends filters depending on the scene that the camera detects in iA (Intelligent Auto) or iA Plus mode. Furthermore, iA Plus mode allows users to adjust defocusing area in the background, exposure compensation and white balance for more flexible control while activating automatic shoot assist functions such as AF Tracking, Intelligent ISO Control, Intelligent D-range Control, Face Recognition and Intelligent Scene Selector.
    For beginner users of interchangeable lens system cameras, the LUMIX G5 features the new Scene Guide which offers 23 sample pictures shot by professional photographers. Users can choose the photo closest to the situation that they are shooting and optimal parameters for shooting the scene will be set automatically. Additionally, procedures, technical advice and recommended interchangeable lens options for the scene can be shown to allow users to better understand and learn photography.
  2. #2522
  3. #2523
  4. #2524
  5. #2525
  6. #2526
  7. #2527
    DPP不好用嗎? 換LR吧...
  8. #2528
    我一直都用capture one,從3.0開始到現在沒變過呀
  9. #2529
    難怪照片一成不變, 老是套用自動...
  10. #2530
