第202頁,共268頁 第一第一 ... 102152192200201202203204212252 ... 最後最後
顯示結果從 2,011 到 2,020 共計 2677 條
  1. #2011
  2. #2012
    可翻轉的LED感覺好low喔........
    可是實際運用上, 卻是蠻方便的啦 .. 這算是輕便機身的重要功能, 不是頂級機需要的啦
    虛空有時盡 我願仍無窮
  3. #2013
    我是說可以放很low拍........讚啦!
  4. #2014
    預設 FUJIFILM FinePix X100
    型番FinePix X100 発売日2011年3月5日 価格¥OPEN(予想実売価格130,000円前後) ・製品の詳細
    【SPEC】●有効画素数:1230万画素 ●撮像素子:APS-Cサイズ 正方画素CMOS CCD原色フィルター採用 ●記録メディア:内蔵メモリー(約約20MB)、SD/SDHC/SDXCメモリーカード ●レンズ:フジノン単焦点レンズ f=23mm (35mmフィルム換算:約35mm相当) ●液晶モニター:2.8型低温ポリシリコンカラー液晶、約46万ドット(視野率 約100%) ●外形寸法:126.5W×74.4H×53.9Dmm ●質量:約405g (バッテリー、メモリーカード含まず)
    http://www.fujifilm.co.jp/corporate/...ffnr_0479.html
  5. #2015
  6. #2016
  7. #2017
    預設 Pentax K-5 Limited Edition Silver Digital SLR Camera
    PENTAX announced its K-5 digital SLR will be available soon in Limited Edition Silver. Available in the US in limited quantities this special-edition model of the PENTAX K-5 digital SLR camera will feature an exclusive design with an original exterior color scheme and a uniquely shaped grip.
    Along with the silver K-5, PENTAX announced three popular PENTAX DA Limited Edition Silver lens models designed for use with PENTAX digital SLR cameras also which will ship in the near future. Each limited edition lens will feature a high-quality, silver finish applied to the high precision machine shaped lens barrel, hood and cap.
    The three prime lenses that will be available in silver include:
    • smc PENTAX-DA 21mm F3.2 AL Limited Silver
    • smc PENTAX-DA 40mm F2.8 Limited Silver
    • smc PENTAX-DA 70mm F2.4 Limited Silver
    The special edition, silver finish K-5 will match existing PENTAX FA-Limited series lenses and the new DA Limited Silver series lenses. The camera's mode dial, control buttons and levers all feature the elegant silver color. To improve handling, this special-edition model comes with an exclusively designed grip that is thicker than the standard K-5 model. Shock-resistant, scratchproof reinforced glass has been used to protect the LCD monitor on the camera's back panel and the status panel on the top panel.
    First announced in September 2010, the K-5 DSLR offers a true high-end, weather-resistant prosumer design and features normally found only on the most costly of professional cameras including:
    • High resolution 16.3 megapixel CMOS sensor.
    • Fast 7 FPS to capture fast action shots.
    • A high sensitivity 80-12800 ISO range, expandable to 51200, with improved noise performance overall.
    • Widescreen 1080p HD video at 25 FPS with sound via built-in microphone or external 3.5mm stereo microphone jack.
    The unique DA Limited series of prime lenses offers incredible sharpness and image quality, and are made specifically for PENTAX DSLR cameras. These lenses are ideal for even the most discerning photographer who demands top performance in an ultra-compact package. The high-grade aluminum construction of the DA Limited series provides the utmost durability and elegant design.
    Price and Availability
    Whether paired or purchased separately, the Limited Edition Silver K-5 and the smc PENTAX DA Limited Silver lenses will offer owners a classic, high-end photography expererience. Priced at $1,699.95 (body kit), the PENTAX K-5 Limited Edition Silver will be available in April 2011.
    The PENTAX DA Limited Edition Silver lens pricing and availability are TBA.
  8. #2018
    預設 Canon EF 500mm and 600mm f/4L IS II USM Lenses
    Canon today announced two new versions of its popular Image Stabilizer (IS) super-telephoto lenses. The EF 600mm f/4L IS II USM and EF 500mm f/4L IS II USM super-telephoto lenses deliver incredible image quality at all apertures for professional photographers and filmmakers. It has been 11 years since Canon initially introduced its Image Stabilized 500mm and 600mm lenses and in that time the Company has listened to feedback from professionals and worked to implement their most desired enhancements. Replacing the current EF 500mm f/4L and EF 600mm f/4L IS lenses, both the new EF 600mm f/4L IS II USM and new EF 500mm f/4L IS II USM have experienced a drastic weight reduction making them lighter and more durable than their predecessors. Both lenses also achieve a higher level of image quality through the incorporation of two fluorite optical lens elements which help to minimize chromatic aberration and eliminate color blurring around the edges of the subject. Both new lenses offer improved Image Stabilization, providing the equivalent shutter speed of approximately four steps faster in addition to enhanced durability and operability through thoroughly re-designed optical and mechanical components.
    Lighter, More Durable and Enhanced
    Canon engineers succeeded not only in reducing the overall weight of these lenses but improving on their optical performance as well. The optical formula of each new lens was re-designed to include two fluorite elements instead of one fluorite and two Ultra-low Dispersion (UD) glass elements. The new lens element configuration weighs less yet performs better. Other factors contributing to the overall weight reduction include increased use of magnesium alloy, use of titanium and a smaller and lighter Image Stabilizer mechanism.
    Optically, both lenses will outperform their predecessors through the use of two fluorite elements over the previous one fluorite and two UD glass elements. More fluorite results in better image quality as it reduces chromatic aberration to a greater degree than UD glass. The reduction of chromatic aberration contributes to superior resolution, contrast, and color fidelity; this is especially evident when used in conjunction with Canon's Type III EF Extenders. In addition to the fluorite lens elements, the new super-telephoto lenses also include a nine-blade circular diaphragm for a smoother appearance in areas outside the depth of field of the main subject. In addition, Canon's SWC (Subwavelength Structure Coating) is applied to four internal groups in each lens to improve resistance to flare and ghosting.
    A convenient and useful feature when shooting in the often adverse conditions professionals find themselves in, these new lenses are treated with Canon's new fluorine anti-smear lens coating. The fluorine layer is highly oil- and water-repellent so that any oil smears or water droplets on the lens can be wiped off quickly and easily, without the aid of solvents, using a soft dry cloth.
    The new Series II EF super-telephoto lenses can correct camera shake up to four full shutter speed steps, compared with two shutter speed steps with their predecessors. This improvement is made possible by a new low-friction stabilizer mechanism that is not only more efficient than the previous design but also smaller and lighter. Other enhancements to the IS systems of both new super-telephoto lenses have enabled quieter operation; ideal for use during video capture.
    Canon has developed a third Image Stabilization mode option for its super-telephoto EF lenses. First introduced in late 2010 with the EF 400mm f/2.8L IS II USM, and EF 300mm f/2.8L IS II USM lenses, and now available on the new EF 500mm f/4L IS II USM and EF 600mm f/4L IS II USM lenses, IS mode 3 is designed to provide professional sports and wildlife photographers with greater tracking flexibility. When mode 3 is selected on the lens, the Image Stabilization effect will not occur until the shutter is pressed, making the viewfinder image more natural in appearance while tracking a subject. In mode 3 when the shutter button is pressed halfway, the lens will begin detecting camera or lens movement and only during exposure, when the shutter is fully depressed, will the Image Stabilization engage.
    Helping filmmakers achieve smoother and more appealing focus shifts when filming on EOS DSLR cameras, Canon has included a new Power Focus (PF) mode on the Company's new super telephoto lensesi. This mode allows manual rack focusing to be operated smoothly by turning a playback ring that is normally used for the focus preset function. Both low-speed and high-speed focus shifting are available.
    Additionally, a new security slot attachment has been included on both of the new super-telephoto lenses to allow a wire-type security lock to be easily affixed, a great safety feature for professionals shooting from high vantage points above arenas and crowds.
    Canon EF 500mm f/4L IS II USM Lens for Sports and Nature Photography
    The Canon EF 500mm f/4L IS II USM offers professional photographers a lighter weight option for those situations that require a long focal length with improved image quality and enhanced durability over its predecessor. Great for a wide range of applications, the EF 500mm f/4L IS II USM lens is ideal for professional photojournalism, sports photography and nature and wildlife photography. The optical formula of the new lens has been enhanced to include two fluorite lens elements for improved image quality and reduced chromatic aberration. Helping to reduce photographer fatigue and make the lens more portable, Canon has reduced the overall weight of the lens by 18 percent from 136.5 oz to 112.5 oz. The Image Stabilizer provides an equivalent of approximately four full shutter speed steps of shake compensation and has been enhanced through the incorporation of a rolling-ball-friction system in place of sliding parts in the compensation optics barrel for a minimum-friction structure. The overall durability of the lens has also been enhanced through increased usage of magnesium alloy and titanium for lens barrel components, together with weather sealing for all exterior joints and switches and a new fluorine anti-smear coating applied to the front and rear elements.
    The Canon EF 500mm f/4L IS II USM lens is expected to be available in May for an approximate retail price of $9,499.
    Canon EF 600mm f/4L IS II USM Lens for Wildlife and Photojournalism
    The Canon EF 600mm f/4L IS II USM is the successor to the current EF 600mm IS lens first introduced in 1999. This new lens has been engineered for outstanding optical performance and durability and includes two new fluorite lens elements for improved quality and reduced chromatic aberration. Helping photographers in the field, Canon has reduced the overall weight of the lens by a substantial 27 percent from 189.1 oz to 138.3 oz. The Image Stabilizer provides an equivalent of approximately four full shutter speed steps of shake compensation and has been enhanced through the incorporation of a rolling-ball-friction system in place of sliding parts in the compensation optics barrel for a minimum-friction structure. The overall durability of the lens has also been enhanced through increased usage of magnesium alloy and titanium for lens barrel components, together with weather sealing for all exterior joints and switches and a new fluorine anti-smear coating is applied to the front and rear elements.
    The Canon EF 600mm f/4L IS II USM lens is expected to be available in June for an approximate retail price of $11,999.
  9. #2019
  10. #2020
    預設 Olympus PEN E-PL2
    Olympus has introduced the PEN E-PL2, the fourth generation of the Olympus PEN family of compact interchangeable lens digital cameras. Known for pro quality, point-and-shoot simplicity and high-definition video, the PEN E-PL2 continues the PEN family's legacy of simple design, intuitive interface and Digital Single Lens Reflex (DSLR) image quality. The new camera also expands your creative potential with Live Guide, new in-camera creative features, new auxiliary lenses, a new Close-Up Spotlight accessory (MAL-1) and the new Olympus PENPAL Bluetooth accessory. Capturing amazing still images and HD video just got a lot more fun. Further proof that Olympus lets you capture it all.
    Features:
    • MSC Lens - the new Movie & Still Compatible (MSC) ED m14-42mm f3.5/5.6 zoom lens (28mm-84mm equivalent) features a high-speed, silent autofocus during still shooting and high definition (HD) video capture;
    • New 3" 460,000 dot LCD - for bright and easy image composition;
    • Live Guide - preview HD video and still image effects on the E-PL2's high-resolution LCD screen to achieve the perfect result effortlessly;
    • Art Filter Variations and Enhancements - choose from different art filter looks to expand your creative horizons or overlay different art filters to create something new, now with full manual control;
    • ISO 6400 - take great low-light photos with the camera's increased ISO sensitivity;
    • New Ergonomic Body Design - shoot stills and videos comfortably with a more ergonomic grip and updated button placement and functionality for ease of use; and
    • Face Detection with Eye Detect - an amazing new function makes it easier to capture the spirit of your subject, automatically making a person's eye the focus point of the image. The E-PL2 further reduces the chance of blurred subjects in images by recognizing up to eight faces, tracking them within the image area, and automatically focusing and optimizing exposure for sharp portraits.
    At an affordable $599.99 with the new MSC ED m14-42mm f3.5/5.6 zoom lens (28mm-84mm equiv.), the 12.3 megapixel ergonomically-designed E-PL2 is perfect for everyone from beginners, who want to expand their creative horizons, to experienced photographers who desire high-quality results without the size and weight of a traditional DSLR.
