第12頁,共268頁 第一第一 ... 210111213142262112 ... 最後最後
顯示結果從 111 到 120 共計 2677 條
  1. #111
    引用 作者: 小佐 查看文章
    實在迷死人啦~~~~~~~~:P
    記得一定要買一支大砲~~~老大一定不要錯過~~:O:O8)
    http://tw.f3.page.bid.yahoo.com/tw/a...55253?u=pjack1
    http://forum.digi-matrix.com/redirec...&goto=lastpost
    毒圖!!!:O:O:O
    http://www.rollei.club.tw/discuz/vie...extra=page%3D1
    :P:P
    真是毒圖!!!
    害我又心動了
  2. #112
    下午過來,我陪你:P:P:P
    引用 作者: twc 查看文章
    真是毒圖!!!
    害我又心動了
  3. #113
    引用 作者: twc 查看文章
    真是毒圖!!!
    害我又心動了
    twc大大~~這真是鏡皇中的鏡皇:O:P:*
  4. #114
    引用 作者: twc 查看文章
    真是毒圖!!!
    害我又心動了
    哇, 果然是毒圖.....
    twc 手骨勇, 買下去!!!
  5. #115
  6. #116
    Panasonic LUMIX DMC-GH1
    Digital SLR Camera
    ‧New Micro Four Thirds Digital Camera With HD Recording Capability
    ‧provides cutting-edge video recording features, including the ability to record high-resolution full HD (1920 x 1080) video at 24 fps or smooth HD video (1280 x 720) movie at 60 fps using an AVCHD format (MPEG-4/H.264).
    ‧LUMIX G VARIO HD 14-140mm/F4.0-5.8 ASPH./MEGA O.I.S lens was specifically designed to support HD movie recording and features a silent motor and continuous auto focusing (AF) capability; two features which distinguish the LUMIX GH1 from DSLRs that offer HD video recording capabilities
    ‧The brilliant 1,440,000-dot equivalent Live View Finder system
    ‧12.1-megapixel high speed Live MOS sensor and Venus Engine HD
    ‧multi-aspect type sensor allows users to take photos in 4:3, 3:2 or 16:9 aspect ratios
    ‧O.I.S. (Optical Image Stabilization) to help reduce blurring from hand-shake
    ‧easy-to-use, thanks to Panasonic's iA (Intelligent Auto) mode
    ‧multiple-area AF with up to 23 focus areas
    ‧Supersonic Wave Filter dust reduction system
    http://www.letsgodigital.org/en/21655/panasonic-lumix-dmc-gh1/
  7. #117
    LUMIX G VARIO HD 14-140mm/F4.0-5.8 ASPH./MEGA O.I.S.
    LUMIX G VARIO 7-14mm/F4.0 ASPH
  8. #118
    Nikon F-mount Celebrates 50th Anniversary
    Evolution of the Nikon F-mount
    ‧Introduced on Nikon's first lens-interchangeable SLR, the Nikon F (1959)
    ‧Auto aperture indexing enables automatic setting of maximum aperture (1977)
    ‧Program auto exposure mode compatibility (1981)
    ‧Aperture information exchange with the camera body through CPU communication (1983)
    ‧Autofocus compatibility (1983)
    ‧Digital SLR cameras compatibility (1995)
  9. #119
    Canon's TS-E 17mm
    This lens will run about $2,500 when it appears in May.
    Its slightly less wide angle brother, the TS-E 24mm, will come in at $2,200 when it shows up as well.
    http://dvice.com/archives/2009/03/the_sexiest_len.php?p=4&cat=undefined#more
    超水的50個樣本
    http://www.smashingmagazine.com/2008/11/16/beautiful-examples-of-tilt-shift-photography/
  10. #120
    小弟三年半前有排排樂過,現在工作忙也很少拍照了
